Help with MF GC 1705 to 1720 series Power Beyond...
   / Help with MF GC 1705 to 1720 series Power Beyond... #11
I agree your diagram is likely in error. It doesn't help that they use dashed lines for both part outline and some hoses. The "T" line from the FEL should also be shown with a hump around the horizontal power beyond line. This is where hands on trumps book knowledge. Go get greasy when it warms up.
Without a defined use for the PB capability and thus, no likelyhood of actual fabrication, I think we have done enough here. Of course, if you need more help, just ask.
I agree to we have taken it about as far as it can go, but your help has been invaluable, its pushed me in direction of understanding how system works I thank you sir.
Only thing I could hope for now is if someone has their 1700 series apart and could supply actual pictures....
Dale
   / Help with MF GC 1705 to 1720 series Power Beyond... #13
I have to tighten the quick connects on my GC1720 (again), so I'll try to trace out the hard (and soft) lines compared to that diagram.
Going to reopen this thread as I think I have resolved some of the issues of how plumbing for backhoe is configured and how the MF shop manual may have it wrong... It also makes more sense if the hydraulic connections were used to add BP if no BH is on machine...
This would be hydraulics WITHOUT either FEl or BH...
This picture is with just FEL and 3PH in hydraulic system (1705-1715) ...
This is where MF shop manual gets it wrong with added BH...
This is corrected diagram of FEL to BH (BP?) then to 3PH.. #6 could be either BH or a BP valve assembly ...
Dale
   / Help with MF GC 1705 to 1720 series Power Beyond... #15
Your last figure looks right. Now, what are you gonna do with this knowledge?
   / Help with MF GC 1705 to 1720 series Power Beyond... #17
I don't think you'd like a log splitter at 4 gpm. Too slow. Something where flowrate is of little concern like a top cylinder or grapple might be useful. I have both and use them often.
Think the flow rate is something like 6.9 and yes I know its slow, but so am I at 75 years old....
Dale
   / Help with MF GC 1705 to 1720 series Power Beyond... #19
Your pictures show a maximum of 18.7 liters/minute or just under 5 gpm. And, it will be less under load.
But I was really impressed with this.....
Splitting fun 3 point wood splitter Massey Ferguson GC - YouTube
Seems to be a DR unit (reported to be out of production now) ....
13 Ton Dual Split 3 point Tractor Mount - TMH1315 | Brave
Note GPM rating and cycle time...
And why is it you to keep pushing back on me when it's my project and my goal.... Maybe if nothing else it gains knowledge and it also might help somebody else who has same idea or goal... And maybe someone wants to use BP for some other type of project if its once figured out......
Dale
Manual Aluminum 16ft Man Lift (A57454)
Manual Aluminum...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
Metal Box with 32 Ratchet Straps (A57454)
Metal Box with 32...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
