Help with 3pt tiller tines
   / Help with 3pt tiller tines #21
I think you will be pleased with it. Everyone I till for says that it does a terrific job.
Yes, tilling while holding a steering wheel is definitely a "work smarter" thing.
From the picture I think I have the same tiller with a different name and it's red. Mine came as a package deal in 07 with my Jinma crate tractor from John's Tractor which is now closed. I would appreciate letting us know if you find them as I need a set also. Thanks.
Ended up ordering a set of tines from these guys. https://www.agproductsllc.com/
They are a little bit longer and taller but fit and seem like they are going to work just fine.
This was the email from them,
"If you have a 10 mm bolt that holds the blade into the blade bracket.
The picture I attached shows the two blades that should work. The black
HWG has a tighter curve and is 3/4 inch shorter when rotating which
misses certain Yanmar models of tiller on the frame. They are $9.00
each. If you need the bolt assembly they are $1.00 each. Shipping will
be $23.00 Please call Kathleen at 1-660-874-4455 and let her know which
blade you want and if you need bolts. She does all the paperwork."
   / Help with 3pt tiller tines #24
Thanks for the update! Really appreciate it.
2018 RAM 2500 (A58214)
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
