Help with 3pt tiller tines
   / Help with 3pt tiller tines #21
I think you will be pleased with it. Everyone I till for says that it does a terrific job.
Yes, tilling while holding a steering wheel is definitely a "work smarter" thing.
From the picture I think I have the same tiller with a different name and it's red. Mine came as a package deal in 07 with my Jinma crate tractor from John's Tractor which is now closed. I would appreciate letting us know if you find them as I need a set also. Thanks.
Ended up ordering a set of tines from these guys. https://www.agproductsllc.com/
They are a little bit longer and taller but fit and seem like they are going to work just fine.
This was the email from them,
"If you have a 10 mm bolt that holds the blade into the blade bracket.
The picture I attached shows the two blades that should work. The black
HWG has a tighter curve and is 3/4 inch shorter when rotating which
misses certain Yanmar models of tiller on the frame. They are $9.00
each. If you need the bolt assembly they are $1.00 each. Shipping will
be $23.00 Please call Kathleen at 1-660-874-4455 and let her know which
blade you want and if you need bolts. She does all the paperwork."
   / Help with 3pt tiller tines #24
Thanks for the update! Really appreciate it.
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58216)
2015 LOAD TRAIL...
