Help with 3pt tiller tines
   / Help with 3pt tiller tines #21
I think you will be pleased with it. Everyone I till for says that it does a terrific job.
Yes, tilling while holding a steering wheel is definitely a "work smarter" thing.
From the picture I think I have the same tiller with a different name and it's red. Mine came as a package deal in 07 with my Jinma crate tractor from John's Tractor which is now closed. I would appreciate letting us know if you find them as I need a set also. Thanks.
Ended up ordering a set of tines from these guys. https://www.agproductsllc.com/
They are a little bit longer and taller but fit and seem like they are going to work just fine.
This was the email from them,
"If you have a 10 mm bolt that holds the blade into the blade bracket.
The picture I attached shows the two blades that should work. The black
HWG has a tighter curve and is 3/4 inch shorter when rotating which
misses certain Yanmar models of tiller on the frame. They are $9.00
each. If you need the bolt assembly they are $1.00 each. Shipping will
be $23.00 Please call Kathleen at 1-660-874-4455 and let her know which
blade you want and if you need bolts. She does all the paperwork."
   / Help with 3pt tiller tines #24
Thanks for the update! Really appreciate it.
Okada OKB304B Hydraulic Breaker (A55973)
Okada OKB304B...
(NEW) SOUP KETTLE (A58374)
(NEW) SOUP KETTLE...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
