Help to identify this axle
/ Help to identify this axle #1
skylarkguy
Platinum Member
Dallas Oregon
Mitsubishi MT372, Ford NAA
I picked up this little axle at a garage sale. I'm planning on making a narrow garden dump trailer contraption. The axle is about 31 inches wheel center to center.
I started to look at diassembling it to check/service the bearings...but it seems that it doesn't come apart as expected. The wheels don't appear to be mounted to a hub but look to be 2 pieces that form the hub.
Any thoughts on the original application of this thing...i'll post more picts once i get it apart.
/ Help to identify this axle #2
Let the air out of the tires before you take those bolts out. If they turn decent, and will take grease, I would use them as is. Probably just bushings in there, but I have no experience with what you have.
Kim
/ Help to identify this axle #3
2nd letting the air out before removing the bolts..
/ Help to identify this axle #4
Looks like the kind used on pull around mortar mixers. They don't have spindles the axle just passes through the wheel which rides on bearings.
/ Help to identify this axle #5
Looks like a pretty standard wheelbarrow wheel setup. If it doesnt crunch while turning, i would just grease and leave it. Most of these wheels have nylon bushings, some have needle bearings.
/ Help to identify this axle #6
I'm with Steave on the identification only, I don't see any mortar stuck to the metal.
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
211453 (A62131)
211453 (A62131)
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
LMC Box Blade (A64126)
