Help! Stuck In The Sand
   / Help! Stuck In The Sand #11
There are only three solutions that come to my mind:
1. Heavier tractor.
2. More tractive tires.
3. More delicate technique, as has been suggested.
   / Help! Stuck In The Sand #12
I had a similar problem with my TC 21 D when using the FEL, until I added about 400 pounds to the 3 pt ( I made a cement weight) It is very easy I used a plastic tub, threaded rod and Sacrete. My rear tires are loaded with CaCl, but the rear weight made a big difference. The advice you have been given by others is also good, go slow and take small bites!!!!!!!
I usually have the back blade on the 3 pt but my tires are not loaded, loading the tires might help. Also would it help to put any weight on the towing hitch?
What type of tires do you have?
Thanks for the input!
   / Help! Stuck In The Sand #14
Egon-
Wet sand definitely makes a lot of difference!
A couple of fellows I knew (honest! I wasn't one of them!!) in their youth hung around the beach on weekends during the summer. Lots of people would "cruise" the beach - but some of them didn't have much sense and took their Camaros & other low ground clearance vehicles on to the sand. Before you knew it, sand was spraying as they tried to "gas" their way out.
Well, the fellow and his buddy would find such folks and tell them "We can get you out for $20." Demanded payment BEFORE removal. Anyway, they'd get the $20 and then proceed to "relieve" themselves self just behind the rear tires. As long as the driver didn’t "gun" it, they would often just back right out. The $20? Well, usually went to purchase more "adult beverages" which were then "recycled" and often used on the next goofball that got stuck.
Wet sand - yep - definitely helps traction! /w3tcompact/icons/smile.gif
   / Help! Stuck In The Sand #15
If you're going to work on the beach in sand maybe some really wide turf tires would be the ticket. If you add weight to your industrials I think you would just make matters worse. On most surfaces the weight would help but you probably want to "float" on the sand if you can.
   / Help! Stuck In The Sand #16
BGM,
Larger tires sounds good, but if you don't want to buy new tires....try to deflate the ones you have a bit. Not too much, but enough to give you some more width. I used to do this in my Jeep on the beach. It works well and is standard practice when traveling in the sand. When you're back on hard ground you can fill them again. I guess you're gunna need a compressor now. Excellent excuse for another fine tool to have around.
   / Help! Stuck In The Sand #17
Test the wet sand theory by setting up a sprinkler in an area you would like to have more traction in.
Good Luck
bruce
   / Help! Stuck In The Sand #18
I have R-4 tires, it might help to put weight on the hitch , but I think you would be limited as to how much you could put on. I think the loaded tires would work better for you. This has been discussed in great detail in the past. Try a search and I think you will find lots of info on what to use/ pros and cons.
   / Help! Stuck In The Sand #19
I’ve never had my tractor in sand, but I have been four wheeling in sand with Jeeps many times. The key to sand is to stay as light as possible! Also, use wide tires with low tire pressures, I mean very low, less than 5 PSI. Also, the aggressive tread is only going to make you dig in – which means you’ll dig DOWN. If you’re primarily going to be using your new tractor is sand, then I would see if your dealer is willing to swap your industrials for turfs. Did you tell your dealer at the time you were buying it that you would be using it in sand? If so, they should have known better than to sell you industrials.
   / Help! Stuck In The Sand #20
The whole idea of having a tractor though, is weight and traction. A super light weight tractor, with no traction isn't going to pull a large implimint good... A box blad would be out of the question. A light jeep for floating over the sand is one thing.. but the tractor uses ground engaging equipment.. new story.
Soundguy
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
Case SV280B (A60462)
