Help! Stuck In The Sand
/ Help! Stuck In The Sand #21
I agree with mosey and hosejockey. Sounds like you're talking about beach sand. If so more weight will just let you dig a deeper hole. You need a bigger footprint to stay on top of the sand. Probably the one situation I would say turfs are a superior tire!! Even consider some of the oversized turfs and then, as everyone else mentioned take as big a bite as you can without spinning your wheels.
/ Help! Stuck In The Sand #22
Soundguy – I agree that a tractor is a “ground engaging” piece of equipment. However, there has to be some ground to engage to! Sand and other surfaces, such as bottomless mud and muck, just don’t have a bottom sometimes. Some mud has a solid bottom, so tall skinny aggressive tires will work the best, but other mud has no solid bottom, at least not within a few feet, and that’s when flotation tires are needed. So, you have to work within the limitations. Sand can only provide a limited amount of traction because there’s nothing down there to get a bit on.
Thanks for all the input!
There seems to be three major variables for my application:
Tires
Weight
Technique
After reading everyones input there is no final conclusion on tires or weight. I sent an e-mail to Bridgestone asking them what the best tires for the application are. As for weight I will do an experiment with the back blade off and on and see which gives me better traction with the FEL.
I am happy to report that technique was my biggest problem. After a couple of days of practice the tractor is handling much better. Doing what I need just in smaller increments.
I will keep everyone posted on what Bridgestone says and how the weight experiment goes.
/ Help! Stuck In The Sand #24
BGM72,
I know I am getting in late on this post but I have a fair bit of experience with a project such as yours.
I have a large sugar sand beach. The depth of the soft sand is anywhere from 4" to 12".
I have a Kubota 21hp, FWD, and filled R-4's.
The most effective way for me to move sand and level is to use my rear blade. Not the rake or boxblade.
With the blade angle in the "normal" forward position, I lower the blade until it firmly contacts the sand, then (in reverse), I push the sand where I want it.
The significance of this method is that the wheels are traveling over previously graded sand that is (1) not as deep and (2) somewhat compacted by the weight and action of the blade. The result is very few traction problems. I rarely have to step on the differential pedal.
Hope this helps
Let me make sure I am clear on how you have the blade positioned. You have the curve of the blade facing twords the tractor so that if you were to go forward with the tractor the blade would be bitting in?
Have you tried turf tires?
How much of a difference did loading the tires make?
I really appreciate the help!
/ Help! Stuck In The Sand #26
That is correct.
My previous tractor, a small Kubota had turfs and only two wheel drive. I did not discover this method until I bought my new tractor so I am not able to compare apples to apples. But in my opinon the R-4's are the better choice for this application.
The fact of the matter is, is that traction is not a big issue when using the blade in the manner described.
/ Help! Stuck In The Sand #27
This sounds like what I achieve when leveling with the FEL by angling it slightly down and backing up. Avoids digging in and allows for the implement to float a little when necessary.
bruce
/ Help! Stuck In The Sand #28
Bruce,
I think the main difference in (reversing with a rear blade facing forward) is that the tractor tires are traveling over graded and somewhat compacted soil, which helps to overcome the traction issues.
Your method may be just as effective though.
17802CFL (A64557)
17802CFL (A64557)
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1992 International 8200 Spreader Truck, VIN # 1HSHEDPN2NH418329 (A65563)
1992 International...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2022 EZ-GO ELITE...
