Buying Advice Help Spend My Money
   / Help Spend My Money #21
   / Help Spend My Money #22
”Never under estimate a SCUT.” Can I set precast concrete blocks with a Scut? Ok I wouldn’t expect that from any compact tractor and most utility tractors but a scut has pretty serious limitations. IMG_1040.JPG
   / Help Spend My Money #23
Never under estimate a SCUT. Can I set precast concrete blocks with a Scut? Ok I wouldn’t expect that from any compact tractor and most utility tractors but a scut has pretty serious limitations. View attachment 585719
I guess I miss read the original post....didn’t know he was moving 5k lb road blocks....or had a budget for a $40k TLB.....thought he might need to move some 1/2 ton rocks and 8’ long 30” downed oak....all of which a proper scut can do....all without tearing up your property.
How does that backhoe do at running a generator so you can power a welder or running a boat lift across the neighbors lawn without leaving ruts or maintaining a narrow 55” trail or splitting wood?
Around my property your construction tractor would be very limited, actually it couldn’t do anything.
   / Help Spend My Money #25
You definitely aren’t lifting an 8’ long 30” diameter oak log with the scout. 1/2 ton would being generous. I think the op would be a lot better served with the increased loader capacity and ground clearance of a L series or at least a B series. I suppose if I really felt like it I could drive a generator off the front of the backhoe. And I’d never have a rear remote powered splitter. But I never recommend the op buy a full size tlb.
   / Help Spend My Money #26
A B o L series or similar tractor should be more than enough for the long term on 5.5 acres. A scut would probably make the most sense, but I'd probably at least do with a B series. Yanmar makes a small 424 that would be a good match in regards to the machine size and capability.
   / Help Spend My Money #27
B series Kubota sounds about right. For JD that is a 2 or maybe 3 series. For Massey check out the 1500 series. LS is the XG series. Kioti is the DK.
Kubota makes a standard B2601 and a B2650. The B2650 is a bit larger framed and has more features. B2650 will be within that 20k finanaced budget, but at 0% for 60m that is still $333/month payment.
   / Help Spend My Money #28
CK in kioti, DK is the bigger machine, like a grand L in kubotaspeak.
Rural King has TYM, the RK37 perhaps, or it may be a tad large.
Used ones are out there - there's an L2501 on FB kubota forum for $16k with 22 hours, yes, 22.
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
