Help needed- 50 hours service on a 5030
   / Help needed- 50 hours service on a 5030
Mr ttowne66 saved my bacon; he took pics of his, and I finally saw what I was not seeing before. My backhoe subframe significantly hides the drain plugs; just enough access if you know exactly where to look.
Re. the Wix filter; it's kind of funny. Right on Wix's website filter lookup cross-reference it clearly shows the TA04037710 KUBOTA filter as the Wix 57098, which is the one I bought. (It cost me $21; the price on the Kubota from the dealer is $43.)
I called Wix; they told me the Wix 57098 IS NOT listed for a Kubota. Their website says otherwise.
The attached and following photos show the problem with the Wix filter
This photo shows the subtle difference: a metal rim/flange that extends inward from under the gasket.
The Kubota filter has a clear inside diameter all the way to the gasket
This one shows how the magnet cannot sit flush inside of the gasket, but instead rides up onto the aforementioned rim/flange
This is a side profile shot that shows how the interference causes the magnet to sit higher than the gasket, preventing a seal.
Last pic: This is a pump that made the Hydro fluid change pretty painless. It sits/inserts onto a 5 gallon pail, and takes about 5 minutes for 5 gallons. It was about $29 at Northern.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2015 Kenworth T800 National NBT60 60 Ton 5 Section Six Axle Crane Truck (A60460)
2015 Kenworth T800...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
Bucket of New Caulking (A57454)
Bucket of New...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
