Help needed- 50 hours service on a 5030
   / Help needed- 50 hours service on a 5030
Mr ttowne66 saved my bacon; he took pics of his, and I finally saw what I was not seeing before. My backhoe subframe significantly hides the drain plugs; just enough access if you know exactly where to look.
Re. the Wix filter; it's kind of funny. Right on Wix's website filter lookup cross-reference it clearly shows the TA04037710 KUBOTA filter as the Wix 57098, which is the one I bought. (It cost me $21; the price on the Kubota from the dealer is $43.)
I called Wix; they told me the Wix 57098 IS NOT listed for a Kubota. Their website says otherwise.
The attached and following photos show the problem with the Wix filter
This photo shows the subtle difference: a metal rim/flange that extends inward from under the gasket.
The Kubota filter has a clear inside diameter all the way to the gasket
This one shows how the magnet cannot sit flush inside of the gasket, but instead rides up onto the aforementioned rim/flange
This is a side profile shot that shows how the interference causes the magnet to sit higher than the gasket, preventing a seal.
Last pic: This is a pump that made the Hydro fluid change pretty painless. It sits/inserts onto a 5 gallon pail, and takes about 5 minutes for 5 gallons. It was about $29 at Northern.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
SCREENER (A58214)
SCREENER (A58214)
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
6 Inch Stargrip (A57454)
6 Inch Stargrip...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
