Help me decide
/ Help me decide #1
Stan R
Kubota 7040 cab
I have a Kubota M7040. I am going to buy a Landpride Batwing. It will be either the RC3715 or the RC3712. The specs are very close expect the width. My question is will my tractor handle the 15 ft mower? The saleman I have used for over 10 years says get the 12 foot. It will be easier on the tractor. Others have said buy the 15 foot you Your tractor will handle it fine. I plan on used the cutter for some commercial shredding. I am leaning towards the 15 ft and might just have to use a lower speed to shred.
Thanks
/ Help me decide #2
Thanks
Biggest factor in my 35 years of custom mowing experience would be
1.how heavy the grass you are cutting
2. hills.
3. roading
You are on the edge of capability of your tractor. I owned an M-7040 about 10 years ago and wouldn’t want a 15’ mower unless it was a light duty model. An M-7040 is a nice little tractor, but going down steep hills and up steep hills with a 15’ mower pushing you might be tricky. Definitely a “gear down” situation. You’ll also need to stay on top of your blade sharpness because you are borderline on HP.
Are you roading between jobs? I‘d want to make sure you have a full compliment of beacons & flashers. An M-7040 isn’t a speed demon. I like to run from one field to another at 25MPH+ to cut down on wasted time.
Most important I’d need to know more about your terrain & grass height/thickness.
I would suggest a John Deere 15’ lightweight batwing. You’d love that mower.
/ Help me decide
I live in Texas about 1/2 way between Dallas and Houston close to I-45. Most of the land is pretty flat. There are places that how some gentle rises. I expect to cut light to medium stuff and other small bush type plants.
/ Help me decide #4
The other question would be does that tractor have the economy PTO option and do you plan on using it? I pull a 21' Frontier finish mower with mine and run it in EPTO. My tractor stays in EPTO all the time. I pulled that same mower with my old 5310(55HP) prior to this tractor and in EPTO as well.
/ Help me decide #5
I personally thing that on flat land like that you will be fine with the 15 FT batwing. I do agree with HD that I would buy the JD instead of the LP. I saw 2 of those sell on the farm eq auction I was at yesterday. They brought 5 grand each. In fairly good condition.
/ Help me decide
I do not have the EPTO. The other mower in play was the Rhino. The one wiith the same specs was about the same price. The RC3715 or 12 is a medium duty mower.
I am also considering a rhino 4125. It is a 12 ft pretty heavy duty mower.
/ Help me decide #7
I'm not familiar with Landpride cutters. I know the Rhino's are good. I've owned one of them. I'm still in the camp of looking at the JD. That's what all the commercial guys here in SC pull for highway maintenance.
/ Help me decide #8
I’d be SUPER leary of pushing that tractor into anything bigger than 2” brush.
You’ll nuke your PTO clutches with driveline shock.
If you are going to be backing into brush, I’d keep it at 8’.
Straight up grassy fields like you are describing a 12-15 light duty would be perfect.
Once you get into a medium 15’, just spinning up the gearboxes will put too much stress on your PTO.
I like a Deere MX-15 behind an M-7040 for pasture clipping. Tall grass will bog you down too much. If tall (like 4’ +) I’d drop to a 10-12’
/ Help me decide #9
Sounds like a 15 would be just fine too me. I’ve got a M4-071, if I was getting a cutter for it I’d absolutely be looking at a 15, but that’s because I’ve already got a smaller Brushhog for working thick stuff so I know I’d never be pushing it’s capacity with a batwing.
/ Help me decide #10
Here’s my M-7040 with an 8’ Deere twin spindle about 15 years ago.
/ Help me decide #11
I own a landpride RC3715 and jd hx 10’ pull type. I have pulled both with a Kubota m7060. On hills and flats … I’ve mowed my hay meadows and filth. Heavy filth with the jd …. Up hills and down the same for the 15’ on some of my meadows.No problem pulling or holding back. The heavy filth will suck the s*** out of the 7060 when I use the jd. As far as I’m concerned I don’t use the epto, that’s a joke. I don’t have time to mope around when I’m mowing… the tractor is gutless when I use that . It takes hp to mow filth on the kind of ground I mow. I don’t mow heavy with the 15 ft but I do mow heavy grass hay. I would not be afraid to buy the 15 ‘ based on your location. Just my opinion.
/ Help me decide
I have a 3 pt 8 ft. landpride TC 3696 and a 3 pt 6 ft Erskine Brush cutter. I was thinking on trading in the 8 ft. The erskine is made to back into heavy brush. Both would be good for the heavier stuff.
Many of our pasture have ferral hog damage. So going slow is a must for new fields.
/ Help me decide
I am keeping the 8 foot mower and picking up the Landpride RC3715 this afternoon. Thanks for the input.
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
8ft. Metal Drag (A65640)
8ft. Metal Drag...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
