Help,L3010 loader hesitating
/ Help,L3010 loader hesitating #1
okie350
Mounds Oklahoma
L3010 & BX2200
L3010 with a Rhino L2408 loader on it. Loader is straining to pick up the front end of the tractor (Like when you are pushing down trying to compress tree branches) and will make that all to familuar "it's to heavy to lift squealing sound" ,then when you go to raise the bucket it will hesitate for a few seconds before lifting the loader. This all happened literally overnight, any idea of whats up????
This has never happened to anyone????????????????????
/ Help,L3010 loader hesitating #4
It sounds like it is captivating. See if a suction line is mashed flat under the tractor or if you have one that is collapsing under suction. Then check all of your quick disconnects. They can look like they are connected and not be. Good luck finding the problem.
What could cause it to cavitate??? and why would it do it suddenly??
/ Help,L3010 loader hesitating #6
Either one of things mentioned will do it. A line mashed or sucked together or a screen or filter plugged. Anything that doesn't let the fluid to the pump. The squealing could be from the connectors not being connected well enough and having the fluid partly shut off. Check all those thing. I am sure one of them will be the problem. It is often hard to find a problem without being there.
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
2021 John Deere 317G Skid Steer (A62613)
2021 John Deere...
