Help,L3010 loader hesitating
/ Help,L3010 loader hesitating #1
okie350
Mounds Oklahoma
L3010 & BX2200
L3010 with a Rhino L2408 loader on it. Loader is straining to pick up the front end of the tractor (Like when you are pushing down trying to compress tree branches) and will make that all to familuar "it's to heavy to lift squealing sound" ,then when you go to raise the bucket it will hesitate for a few seconds before lifting the loader. This all happened literally overnight, any idea of whats up????
This has never happened to anyone????????????????????
/ Help,L3010 loader hesitating #4
It sounds like it is captivating. See if a suction line is mashed flat under the tractor or if you have one that is collapsing under suction. Then check all of your quick disconnects. They can look like they are connected and not be. Good luck finding the problem.
What could cause it to cavitate??? and why would it do it suddenly??
/ Help,L3010 loader hesitating #6
Either one of things mentioned will do it. A line mashed or sucked together or a screen or filter plugged. Anything that doesn't let the fluid to the pump. The squealing could be from the connectors not being connected well enough and having the fluid partly shut off. Check all those thing. I am sure one of them will be the problem. It is often hard to find a problem without being there.
2015 CATERPILLAR AP1000F ASPHALT PAVER (A65056)
2015 CATERPILLAR...
525 Gal Supply Tank (A64912)
525 Gal Supply...
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A66734)
2007 JLG G6-42A...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
(2) Goodyear 16.9-24 Tires (A64911)
(2) Goodyear...
