Help identify disc
/ Help identify disc #1
cowridermi
Addison, NY
MF 65, MF 1080, MF 1100, Kubuta B8200, Farmall 504, Farmall Cubs, Farmall Super A, Belarus 250AS's, Belarus 611, JD F935
Need to replace bearing but do not know make or model of disc. 10 foot with no tags. Thanks
/ Help identify disc #2
Don't know the make, but you could take the gang apart and see what bearing it is. If you can't see the bearing part number, it can be easily matched.
/ Help identify disc #3
Maybe a White or White Oliver.
/ Help identify disc #4
Remove bearing and measure or take to someone who can.
If you cannot remove bearing, the person than can will figure it out for you.
It's not uncommon for different mfg's to change the parts they use over the years or for that matter, owners solving problems with non factory items.
You can guess or have the part in hand, when you get the replacement.
