tjkubota93
Veteran Member
If both hoses are tight with the engine running at operating temp, the thermostat is stuck.
both hoses are going to be tight even on a properly working engine, because of the pressure with the radiator cap on.. one hose tight, and another soft is a big problem!..If both hoses are tight with the engine running at operating temp, the thermostat is stuck.
No, I can't see the fluid circulate. How would I do that? The bottom hose gets hot, yes.
Yes, I've got full coolant. Both top and bottom hoses seem to increase pressure a little when running, but they both feel about the same, and both easily give when squeezed. Is that a problem?
Removing the thermostat seems like it would be hard to do. Won't I have to carefully drain all the coolant? I think I'd need a service manual to make sure I got it right.
That's Great, if you see any black paint coming off, touch it up with spray paint. the black paint helps it to radiate the heat by a good bit..Closing the loop here. I'm pleased and a little embarrassed to report that cleaning the radiator has apparently solved my problem. I thoroughly cleaned the fins of the radiator that were behind the filter (which I had cleaned). Glad to have saved substantial dollars. Thanks to ch1ch2 and to everyone who offered advice. You all are great.
