Help!!!!!!! Cub Cadet 2135 won't start!!!!!
/ Help!!!!!!! Cub Cadet 2135 won't start!!!!! #1
dirtbikekid
Guys I need help, I have a Cub cadet 2135 that is having starting issues and it has something to do with the blades or pro switch, most times I have to constantly engage and disengage the pto switch for my mower to finally start! After a few tries it will end up starting but the problem is getting worse! Any ideas, is it the switch going bad or a relay? when I turn the key I can hear a click but I have to keep messing with the pto switch for it to finally start! Please help, thanks!!!!
Eric
/ Help!!!!!!! Cub Cadet 2135 won't start!!!!! #2
Do you feel comfortable jumping across from the starter main power(wire from battery to starter) source to the solenoid (small wire on solenoid) and seeing if the unit will start when you are getting the "Clicking" sound instead of playing with the switches?
If yes and the unit starts consider this installation that corrects the Cub Cadet no start clicking sound when turning the ignition switch to the start position.
____________________________________________________________________________________________________
The corrective fix is not that expensive and gives added comfort when starting the mower.
How to fix a no-start or a clicking sound when key turned to start when battery is fully charged.
Purchase a five (5) spade terminal relay. I like the type with a tab. This allows the placement of the relay near the starter with a sheet metal screw. Some like the type that mounts through the use of a bracket. The relay needs to have the following terminals, 30-85-86-87-87a. An auto parts store or Radio Shack can supply. Or, if you want to spend big bucks purchase the relay from Cub Cadet.
Remove the wire from the key switch to the starter solenoid. (Remove the wire at the solenoid - pull from the spade terminal)If you are lucky, install this wire on terminal # 85 on the relay.
If unlucky splice a wire onto the wire so it will reach where you have mounted the relay. Connect a wire to terminal # 86 and attach the other end of the wire to a good ground.
Install a wire on the terminal on the starter where you previously removed the wire from the switch, attach the other end of the wire to terminal # 30 on the relay.
Install a wire with a 20 amp inline fuse on the main battery wire at the starter or another 12 volt source. Connect the other end of this new 12 volt source to terminal # 87 on the relay.
No wires should be connected to terminal # 87a.
Now when you turn the key to start, the voltage from the switch collapses the relay and the new 12 volt source energizes the starter.
/ Help!!!!!!! Cub Cadet 2135 won't start!!!!! #3
post number 2 will help,you might want to check the relay switch (about $10)located around below your fuses it is usually has black electric tape around it peel of the tape you will then be able to remove the relay you will see a orange gasket the 2135 is quite old if the relay does not fix the problem you are not out a lot then you can try post 2
/ Help!!!!!!! Cub Cadet 2135 won't start!!!!! #4
You'll be fighting this as long as you own the tractor. All the lawyer switches are junk and will fail from weather and corrosion.,
I ended up completely rewiring my tractor to bypass all the lawyer switches; reverse deck cut out, seat cut out, brake on to start. They all failed. I rewired everything and use a simple on-off pull switch to activate the deck.
Your results and opinions may vary. Not intended as legal advice. One you set up the tractor this way, only you should operate it.
jack vines
