Help choosing old small tractor
   / Help choosing old small tractor #21
Soundguy,
If you'd filled that tub with ice and your favorite drink, it wouldn't be as good for ballast, but you'd have a lot of friends following you around.
Cliff
   / Help choosing old small tractor #22
</font><font color="blue" class="small">( If you'd filled that tub with ice and your favorite drink, it wouldn't be as good for ballast, but you'd have a lot of friends following you around.
Cliff )</font>
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif good on ya Cliff.
Soundguy, it was your setup that I was thinking about, but yours was done much more inexpensivley that I remembered.
I love the way you fixed up the connections.
John
   / Help choosing old small tractor #23
The 1,500 lb rating per trailer tire only means the tires can carry 3,000 total together. It has nothing to do with the trailer capacity. If you subtract the weight of the trailer itself, you're capacity is probably 2,400 or less, which is just a guess.
   / Help choosing old small tractor #24
</font><font color="blue" class="small">( Soundguy, it was your setup that I was thinking about, but yours was done much more inexpensivley that I remembered.
)</font>
Hey.. i was aiming for cheap, and got there.
The tub was more or less free, as it was a left over cattle feed tub. I used an old drawbar, and bolted it to the bottom of the tub and left the bolts sticking up inthe tub about 6" to anchor to the concrete. Toplink connection is just a flat with holes , cut in 2 pieces. Paid 7 bucks for the flat.. 2 bucks for the nuts/bolts, and 6 or 7 bucks for a few backs of sackkrete..
If I ever toss the concrete chunk, I can spinn 2 nuts off the bottom and salvage my drawbar...
Soundguy
   / Help choosing old small tractor #25
</font><font color="blue" class="small">( I used an old drawbar, and bolted it to the bottom of the tub and left the bolts sticking up inthe tub about 6" to anchor to the concrete. )</font>
I'm glad you added this description. I was wondering what you used for the mount.
Even if one had to buy a new horizontal draw bar, it would be inexpensive to build this. Very inventive and quite utilitarian!
John
   / Help choosing old small tractor #27
The tub is just there to hold the 'crete till it sets. Even a thin throw away one.. perhaps a large tub from a plant nursery .. you might get one for a buck.. or free.. one of the bigger 10-20g ones. Just tape up the inside with duck tape to cover the holes..
Half a 55g drum works too
Soundguy
   / Help choosing old small tractor #28
<font color="blue">My experience is to spend a little more and get a tractor u can do work with instead of a tractor you can do work on. </font>
TAKE THIS ADVICE TO THE BANK!!!
Don't ask how I know. /forums/images/graemlins/frown.gif
Mini John Deere Truck (A55853)
Mini John Deere...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Metal Body Holding Sasquatch (A57454)
Metal Body Holding...
2016 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2016 VOLVO VNM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
