Help... cannot get input shaft back into clutch...
/ Help... cannot get input shaft back into clutch... #21
Kenonf said:
I am not sure about an inspection hole,you think I might get something in there to stop or move inner shaft.
Thanks
Ken
You might be able to if you have one.
/ Help... cannot get input shaft back into clutch... #22
so is this really a dual clutch.. sounding more and more independent single, witht he pto run direct thru
Okay, Finally got back from a job and picked up a couple of parts at the dealer. It is together, I took a little time and watched my alignment. I also removed the gantry crane and put the front and back halves on floor jacks. Every thing else went on easy, finished in about 4 hours. I have run it and no more sticky input shaft. I leave for another job soon and when i get back will remount the middle loader supports, and re install the front loader. With any luck I will be able to level the bucket, after I found out now loose the frame bolts were.
Thanks for the help guys.
Ken
/ Help... cannot get input shaft back into clutch... #24
awesome deal!
/ Help... cannot get input shaft back into clutch... #25
Glad to hear it's back together and working. Sounds like the rust was the culprit.
Sean
/ Help... cannot get input shaft back into clutch... #26
I wondered if you ever got it back together. You are supposed to periodically check the loader bolts and wheel nuts/ bolts.
2017 PETERBILT 579 (A65643)
2017 PETERBILT 579...
2015 TROXELL 130BBL VACUUM TRAILER (A65643)
2015 TROXELL...
3143 (A63117)
3143 (A63117)
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2021 BOBCAT E50 R2 SERIES EXCAVATOR (A63276)
2021 BOBCAT E50 R2...
Mini Universal Wheel Barrow (A65640)
Mini Universal...
