Help... cannot get input shaft back into clutch...
/ Help... cannot get input shaft back into clutch... #21
Kenonf said:
I am not sure about an inspection hole,you think I might get something in there to stop or move inner shaft.
Ken
You might be able to if you have one.
/ Help... cannot get input shaft back into clutch... #22
so is this really a dual clutch.. sounding more and more independent single, witht he pto run direct thru
Okay, Finally got back from a job and picked up a couple of parts at the dealer. It is together, I took a little time and watched my alignment. I also removed the gantry crane and put the front and back halves on floor jacks. Every thing else went on easy, finished in about 4 hours. I have run it and no more sticky input shaft. I leave for another job soon and when i get back will remount the middle loader supports, and re install the front loader. With any luck I will be able to level the bucket, after I found out now loose the frame bolts were.
Thanks for the help guys.
Ken
/ Help... cannot get input shaft back into clutch... #24
awesome deal!
/ Help... cannot get input shaft back into clutch... #25
Glad to hear it's back together and working. Sounds like the rust was the culprit.
Sean
/ Help... cannot get input shaft back into clutch... #26
I wondered if you ever got it back together. You are supposed to periodically check the loader bolts and wheel nuts/ bolts.
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
Great Dane Van Trailer (A63689)
Great Dane Van...
2008 STOUGHTON ZGPVW-535T-SC-AR 53X102 T/A DRY VAN TRAILER (A59914)
2008 STOUGHTON...
LOOK! (A63111)
LOOK! (A63111)
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
