help bucket pin came out of new backhoe bh92
   / help bucket pin came out of new backhoe bh92
good idea. Think I will go on search for a better pin.
IF, and that's a big if, you anticipate changing buckets often there are other shape of retaining pins that are relatively easy to swap by hand but are rarely lost.
For example the guy that dug a trench for my water line changed buckets a couple of times, used a real narrow bucket going across my driveway, bigger bucket for the rest of the work.
   / help bucket pin came out of new backhoe bh92 #12
I don't have a backhoe attachment but every "pin" on the bottom side of my 3-point and ALL implements - I have replaced with a grade 8 bolt and Nylok nut. I was, at one point, loosing lynch/hair pins like they were going out of style. Never damaged or lost anything except the hair pins and the lynch pins.
And, quite honestly, I don't have a lot of brush to speak of.
   / help bucket pin came out of new backhoe bh92 #13
Yeah I would like to get a quick change system with several buckets.
This is what I was referring to - 1/2" Shaft Diam, 1.42" Long, .62" Wire 41239518 - MSC
But there are also "bow tie locking cotter pins"
   / help bucket pin came out of new backhoe bh92 #14
I have found some linchpins that snap closed tighter than a big 'ol rat trap. You have to be careful with them, been snapped more than once, but they definitely are more secure than the standard linch pin. About the only thing I've found that is close to 100% is the grade 8 bolt with Nylock nut. A real PITA if you do frequent changes.
That pin you picture there Newbury looks like some of my son's Chinese puzzles. I kept looking for a way to "undo" it.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1969 Lincoln Continental Mark III Sedan (A56859)
1969 Lincoln...
Tractor (A59228)
Tractor (A59228)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Deere 35P (A53317)
Deere 35P (A53317)
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
