Green Acres Homestead
- Joined
- Dec 11, 2010
- Messages
- 1,174
- Tractor
- Kubota L4740 sold. As of Jan 2023 I have a new L2502.
I got about 30 hours on my kubota backhoe implement and when digging I noticed the bucket pin was sticking out several inches on one side. I inspected and the pin pushed far enough out that I had to line up the buck and pound the pin back in.
two questions.
1. The bolt that goes through the pin was not anywheres to be seen... Is this normal to loose the bolt and the pin back out.
2. Did I reinstall the pin properly..... After pounding the pin back in I lined up the bolt hole and put in another bolt. Something doesn't look quite right. The grease end is sticking out farther than all the other grease ends. Is that normal for the bucket pin. Is there a certain way to install the pin and grease nipple end.
two questions.
