Help, adding new tractor to operation
/ Help, adding new tractor to operation #11
I have pulled a 2200lb pallet out of a semi trailer with my forks with the mahindra... I was certain it would never lift it at that height, but it did. I wouldn't make a habit of it, but it lifted, curled, backed up and eased it to the ground.
You are braver or younger than I.
The safe way to remove a max load is to lift the load just an inch or two off the truck floor, then have the truck slowly drive away before lowering the load to the ground. Sometimes just a small rock or lawn divot under a moving wheel will roll a tractor with a max lift on the FEL.
Mahindra 1526 Attachments​
Mahindra 1526 tractor photo
2016 - 2018
1500 Series
Compact Utility tractor
Mitsubishi built
Mahindra 1526L Loader
Loader weight:774 lbs
351 kg
Height (to pin):84 inches
213 cm
Clearance, dumped bucket:67.5 inches
171 cm
Dump reach:18.5 inches
46 cm
Dump angle:40°
Clearance, level bucket:80 inches
203 cm
Reach at ground:56 inches
142 cm
Rollback angle:20°
Breakout force (at pin):2795 lbs
1267 kg
Lift to full height (at pin):1560 lbs
707 kg
Bucket width:58.5 inches
148 cm
The practical forward positioned pallet lift of a Mahindra 1526L Loader, including Pallet Forks as part of the load, is around 1,200 pounds at 48" truck height.
It is impossible to lift a forward positioned 2,200 pound pallet load with a 2,400 pound bare weight tractor.
/ Help, adding new tractor to operation #12
By a quick look at the spec sheet the Kubota L2501 matches your 1526 as far as weight and hp. If you go above the 25 hp then you get the Tier4 and DPF on the tractor. The L2501 does not have the computer nor the DPF.
The L2501 does lack a few things. The 3rd function for the front and remotes for the rear are not standard. Also you would want to add L8473 telescoping sway bars on the 3 point. I believe you can order R14 tires which might be good for your application, I would check them out anyway. The 3 point arms do not come standard with the telescoping ends.
When I was looking I found the 2 tractors to be a lot alike but I went with the orange one.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 Homemade 7'X20' Trailer w/Ramps (A60462)
2016 Homemade...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
