Help 424 international clutch adjustment
/ Help 424 international clutch adjustment #1
rustyhouser
mt holly NC
424 international
Does anyone know how to adjust the clutch on a 424 International tractor. the clutch does not engage until the pedal is about 3/4" from the top. It will pull in the low gears but not in the high gears.
Thanks Rusty
/ Help 424 international clutch adjustment #2
IT is complicated as it is a two stage clutch!
Can you help me with it or know someone that can?
/ Help 424 international clutch adjustment #4
You would have to loosen the bolt on the clutch shaft and rotate to get 3/4" free play on petal. There should be 6" total travel and that is adjusted with the set screw stop.
/ Help 424 international clutch adjustment #5
:welcome:
To the forum from Northwest Alabama.
