Help 424 international clutch adjustment
   / Help 424 international clutch adjustment #1
rustyhouser
mt holly NC
424 international
Does anyone know how to adjust the clutch on a 424 International tractor. the clutch does not engage until the pedal is about 3/4" from the top. It will pull in the low gears but not in the high gears.
Thanks Rusty
   / Help 424 international clutch adjustment #2
IT is complicated as it is a two stage clutch!
Can you help me with it or know someone that can?
Thanks
   / Help 424 international clutch adjustment #4
You would have to loosen the bolt on the clutch shaft and rotate to get 3/4" free play on petal. There should be 6" total travel and that is adjusted with the set screw stop.
   / Help 424 international clutch adjustment #5
:welcome:
To the forum from Northwest Alabama.
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
JOHN DEERE 4 BOTTOM PLOW (A52708)
JOHN DEERE 4...
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
