Helmet light
/ Helmet light #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So I'm sure I'm not the first person to think of this but...
I was lamenting my cruddy shop lighting and annoyed at having to keep moving work lights while grinding today....
First I was thinking someone probably makes a welding helmet with a built-in head light. Or I could modify my existing helmet.
I had a $15 LED impulse buy from Lowes with an adjustable base lying around. Took off the band. The adjustable base already had a hole in the center.
I drilled a hole in the top and inserted a bolt:
Then mounted the light:
3.5 year old approves:
/ Helmet light #3
Hey, if your 3.5 year old son approves, that is good enough for me. Looks good. Think I'll give that a try too.
/ Helmet light #4
Great idea, so,, did this give you the light you were hoping for? Does it work well?
/ Helmet light
Yes, it definitely helped a lot. Not as good as a perfectly positioned spot light shinning over your shoulder but still good (and much more convenient).
I have only used it for grinding so far. Will do some MIG this weekend.
Again, this is a $15 "checkout isle" LED light. I'm sure there are brighter headlamps out there. If I were starting over, I'd find the brightest spot I could with an adjustable base (if the price was right).
/ Helmet light #6
Now here's a man that can think outside of the box... err helmet. This may be the start of a fix to an age old problem. Good thinking Luke!
Please let us know what you think about this after a bit of welding.
/ Helmet light #7
This made me smile as I remembered the countless times my dad would say (as I was holding a flashlight over his shoulder) "Point the light where I'm looking, not where you're looking". :)
Thanks to helmet lights etc, I rarely get to tell my son that same thing.
/ Helmet light
Thanks Gem,
So I used it MIG welding yeasterday and it did not mess with the auto darkening (I did not have to change any settings).
I looked when I was at Lowe's and the model I have says 150 lumens on the packages. If I were starting over I'd get the 250lumen one for $5 more.
/ Helmet light #9
I'm going to have to try this... have a couple of light weight camping headgear LED lights. One might find its way to my shop!
/ Helmet light #10
Thanks Gem,
I'm looking at what's called a 'miner's headlight' on Amazon for $5.89. The description says "9pc 11,000 MCD Ultra Bright LED Bulbs". I sure don't know how to convert that description into lumens, but I'm going to give it a shot. The idea is just way too good to not try it too.
/ Helmet light
Let me know how it turns out.
/ Helmet light #12
Nice idea. I have a super bright headlamp I used to use ice fishing. I think I will try it. Has to be better than the clip-on drop light I have now. Thanks for posting.
gg
/ Helmet light #13
Even with an auto-darkening helmet, you need light! I do like the clip-on incandescent, though, because I look at the lite bulb, just to check the auto-darkening function. If it doesn't trigger the helmet, your eyes aren't getting flashed.
/ Helmet light #14
My adult son was telling me the other day about the time, long ago, when we replaced an element in a water heater. He said he probably held the flashlight. I'd forgotten about it but it seemed to mean something to him.
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
6R BEDDER (A63291)
6R BEDDER (A63291)
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
