Helmet light
/ Helmet light #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So I'm sure I'm not the first person to think of this but...
I was lamenting my cruddy shop lighting and annoyed at having to keep moving work lights while grinding today....
First I was thinking someone probably makes a welding helmet with a built-in head light. Or I could modify my existing helmet.
I had a $15 LED impulse buy from Lowes with an adjustable base lying around. Took off the band. The adjustable base already had a hole in the center.
I drilled a hole in the top and inserted a bolt:
Then mounted the light:
3.5 year old approves:
/ Helmet light #3
Hey, if your 3.5 year old son approves, that is good enough for me. Looks good. Think I'll give that a try too.
/ Helmet light #4
Great idea, so,, did this give you the light you were hoping for? Does it work well?
/ Helmet light
Yes, it definitely helped a lot. Not as good as a perfectly positioned spot light shinning over your shoulder but still good (and much more convenient).
I have only used it for grinding so far. Will do some MIG this weekend.
Again, this is a $15 "checkout isle" LED light. I'm sure there are brighter headlamps out there. If I were starting over, I'd find the brightest spot I could with an adjustable base (if the price was right).
/ Helmet light #6
Now here's a man that can think outside of the box... err helmet. This may be the start of a fix to an age old problem. Good thinking Luke!
Please let us know what you think about this after a bit of welding.
/ Helmet light #7
This made me smile as I remembered the countless times my dad would say (as I was holding a flashlight over his shoulder) "Point the light where I'm looking, not where you're looking". :)
Thanks to helmet lights etc, I rarely get to tell my son that same thing.
/ Helmet light
Thanks Gem,
So I used it MIG welding yeasterday and it did not mess with the auto darkening (I did not have to change any settings).
I looked when I was at Lowe's and the model I have says 150 lumens on the packages. If I were starting over I'd get the 250lumen one for $5 more.
/ Helmet light #9
I'm going to have to try this... have a couple of light weight camping headgear LED lights. One might find its way to my shop!
/ Helmet light #10
Thanks Gem,
I'm looking at what's called a 'miner's headlight' on Amazon for $5.89. The description says "9pc 11,000 MCD Ultra Bright LED Bulbs". I sure don't know how to convert that description into lumens, but I'm going to give it a shot. The idea is just way too good to not try it too.
/ Helmet light
Let me know how it turns out.
/ Helmet light #12
Nice idea. I have a super bright headlamp I used to use ice fishing. I think I will try it. Has to be better than the clip-on drop light I have now. Thanks for posting.
gg
/ Helmet light #13
Even with an auto-darkening helmet, you need light! I do like the clip-on incandescent, though, because I look at the lite bulb, just to check the auto-darkening function. If it doesn't trigger the helmet, your eyes aren't getting flashed.
/ Helmet light #14
My adult son was telling me the other day about the time, long ago, when we replaced an element in a water heater. He said he probably held the flashlight. I'd forgotten about it but it seemed to mean something to him.
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
