hello miner here
/ hello miner here #1
miner
crofton,kentucky
mahindra m85p and 7520 and int 806
i have a m85p mahindra and a 7520 anyone having trouble with air cond on their cab tractor was wandering if it's 80deg outside what should cab temp be inside
/ hello miner here #2
Welcome to the TBN forum!
:welcome:
I'm going to move your thread on over to our Mahindra section to see if we can find you an answer. :tractor:
/ hello miner here #5
G'day Mate and welcome to TBN from Downunder.
Enjoy the site... especially now that Catherine has shifted you over to a more specific thread.
/ hello miner here #6
Welcome Miner, I'm no diesel mech, but I am an HVAC Tech. The cab should be comfortable with the AC on with an outside temp @80. Should be able to get around 50 degrees out of the vents. Take a peak at the condenser coils to make sure they aren't packed with dirt and debris. However others will chime in soon. There is a Mechanic that frequents these threads and is a huge help (Jabonee) and I hope he don't mind the name drop. Daves Tractor is another big contributor and asset to Mahindra info. Good Luck in the mean time.
/ hello miner here #7
Definitely check the condenser,evaporator and HVAC filter for blockage. Is the compressor turning? Is the fan running? Try/inspect these things first.:thumbsup:
/ hello miner here
I've checked these but thinks Jabonee. I've had it a 2 different dealers it's still under warr. First said it had to much freon the other said not enough. Not sure what's going on
/ hello miner here #9
Both reasons will keep it from operating correctly...
/ hello miner here #10
I think my next step would be to find out if the dealers your dealing with are HVAC CERTIFIED. PSI to high or low will cause the compressor not to run. Other possibilities are heater control valve and mixing gate.:confused3:
/ hello miner here #11
Im betting to much was let out... simple check of the gages will be able to tell whats happening... Havnt had much issues out of those ACs... its a much better system than any of their others
/ hello miner here #12
That s why I question the dealers. Gauges are only a diagnostic tool. Without looking up the spec I'm guessing the system holds 2 to 3 lbs. Did they evacuate the system and measure? I'm guessing not. The dealer that said it was high probably only saw a high reading and assumed there was too much. Thats bad because high psi can be caused by a bad expansion valve. Connecting to both high and low sides and making sure the psi is equal would be my first step. Then start the engine,observe the readings. Now shut it all off. You should see the pressures begin to equalize.If not the expansion valve may be bad or blocked. This leads me back to say, make sure the dealer you have is HVAC certified. :cold:
/ hello miner here
Thank you Jabonee I'll check and see
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2019 Chevrolet Express 2500 Cargo Van (A61573)
2019 Chevrolet...
