Hello & 1862 steering???
/ Hello & 1862 steering??? #1
kevinj1
Hello people I am new to TBN I have a small hobby/side business working on lawn and snow equipment. I also belong to The Diesel Stop forum and have found it to be very helpful when fixing my truck. I am sure I will find all of you to be as helpful and I hope I maybe helpful too. I am working on my neighbor's
Cub Cadet 1862 and the steering turns farther to the Right than left, there is a little play in the center pivot pin but I don't think its enough to cause this much differance. any help or thoughts would be greatly appreciated.
Thanks Kevin
/ Hello & 1862 steering??? #2
Kevin,
The steering is controlled by a proportioning valve driving a cylinder. Ther is a good chance the valve is not balanced. If you remove one end of the cylinder (Left side of tractor), I'm betteing the travel will be closer to equal.
Good Luck, you can go to "Ihregistry.com" for manuals.
Curt
Curt,
Thank you for the info. I noticed the rod doesn't retract all the way into the cylinder, it looks like its been a while the rod it pitted.I'll check out the manual link.
Thank you again Kevin
2018 F-150 4WD (A63688)
2018 F-150 4WD...
2022 EZ-GO ELITE...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
