Ballast heavy wheel weights M7040
/ heavy wheel weights M7040 #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
here is how I mounted the wheel weights without having a forklift like the dealers. Very simple to do and saves a lot on the back. All about leverage
/ heavy wheel weights M7040 #2
Neat idea.
How much do the rings weight each?
/ heavy wheel weights M7040 #3
Was thinking the same question. I have loaded the tires, but wouldnt mind have a few of these hanging around. Where did you find those?
Thanks
They are 200 lbs plus so very difficult to handle without a FEL or forklift. They are from the kubota dealer and is a regular option for the M7040. Mounted three rings on each side also have Cast iron hubs as well as filled tires
Decided to only use two wheel weights per wheel. The third weight just protrudes completely outside the side wall of the tire. So I have two wheel weights for sale if someone is interested. I am located Frederick
Maryland. They are heavy so if you are closeby maybe best to save on freight cost
/ heavy wheel weights M7040 #7
Looks like you came up with a good way to handle the wheel weights. Now, just wondering what you are doing that requires all that weight?
/ heavy wheel weights M7040 #8
I have an M7040. Before I put water in the tires, a full load of dirt in the bucket you could bounce the rear tires off the ground by just wiggling the bucket with the hydraulics. If you wasn't on perfect level ground...that tends to increase the pucker factor quite a bit.
I also have a grapple, and even with loaded tires I at times still pull the rear wheels off the ground, doing work with it.
I wish I had those weights.
/ heavy wheel weights M7040 #9
Congratulations, that is an elegantly simple solution to a difficult task. Forgive me if I'm a little slow on the uptake, but I couldn't tell by the picture just how you attached the 2x4 at the wheel. Looks like another block of wood, maybe with a notch in it?
I'm also curious, as the others, as to why you need so much extra weight (400 lbs. each side) above and beyond the weight of the filled tires, and you wanted to add even another 200 lb. ring!
Hi Jim, yes on the wheel hub I nailed three short pieces of 2 by 4's together the middle piece being shorter to allow the long 2 by 4 to be inserted so place the block inside the hub stick in the long 2 by 4 and then slide up the wheel weight up the long 2 by 4 until I have leverage to lift the end up on the jackstand. The weight is used for traction when excavating. It allows me to go down 6 inches or so with the bucket and fill it without stopping in one smooth motion. Also have a ballast box that I used on occasion
Jcummings, you are so right that weight on the rear makes this a safer tractor when lifting. I have 73 inch Bradco 4 in one bucket that adds to the weight in the front. Before adding weight I was very skittish about lifting very high.
/ heavy wheel weights M7040 #12
I have a M6800 and I put 2 weights on the inside of the rims and you can barely see them. I took the wheels off and used my motor puller and laid the tires on the floor, put the weights on, raised the wheels up and put them back on. It took me a little over and hour.
/ heavy wheel weights M7040 #13
Hi,
I have just traded for a Kubota M4900 w/loader 2 wheel drive with dual wheels can I mount the wheel weights on the inside of the wheels so I don't have to take them on and off when I put the duals on?
It should be delivered next week I can't wait!!:D
/ heavy wheel weights M7040 #14
Are the wheel weights still available?
/ heavy wheel weights M7040 #15
Bingo.
I mounted only two such weights to the cast centers of my M9960 for the same reason.
/ heavy wheel weights M7040 #16
The Kubota M8126A weights as pictured are 164 Lb. each. The required bolts probably weights another 5+ Lb.s per weight.
/ heavy wheel weights M7040 #17
I have 1550# of RimGuard in the rear tires plus a 1100# Rhino rear blade on the 3-point. I use my grapple to move rocks and chunks of pine tree trunk.
As I remember - back in 2009 when I bought the M6040 - cast wheel weights were excessively expensive. I think it required that the rear rims had to be cast also. That's why my $$$ went into RimGuard and a rear blade.
The rear blade is more than just added weight.
BTW - simply splendid DIY method on adding those weights.
/ heavy wheel weights M7040 #18
I like my tractors heavy and my chics light. M5-091 cast centers, weights and radials.
/ heavy wheel weights M7040 #20
Nice ground.
Thanks. I grew up on this farm, I spent many of my formative years plowing this farm with a International 656 and a semi mounted 4-14s plow. When I saw this plow for sale, I couldn't resist, I use it for "Recreational Plowing".
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
2012 Mazda 3 Sedan (A61574)
2012 Mazda 3 Sedan...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2005 John Deere 7420 (A60462)
2005 John Deere...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
