m7040
Elite Member
- Joined
- Sep 15, 2006
- Messages
- 4,188
- Location
- Frederick maryland
- Tractor
- Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
Are the wheel weights still available?Decided to only use two wheel weights per wheel. The third weight just protrudes completely outside the side wall of the tire. So I have two wheel weights for sale if someone is interested. I am located Frederick
Maryland. They are heavy so if you are closeby maybe best to save on freight cost
Bingo.Decided to only use two wheel weights per wheel. The third weight just protrudes completely outside the side wall of the tire. So I have two wheel weights for sale if someone is interested. I am located Frederick
The Kubota M8126A weights as pictured are 164 Lb. each. The required bolts probably weights another 5+ Lb.s per weight.They are 200 lbs plus so very difficult to handle without a FEL or forklift. They are from the kubota dealer and is a regular option for the M7040. Mounted three rings on each side also have Cast iron hubs as well as filled tires
Nice ground.
