Heat Pump and power consumption
   / Heat Pump and power consumption #81
I have an ecobee.
I too like it.
But dont understand the idea of it saving energy?
It is "supposed" to have algorithms that learn your habits (time vs temp and rollbacks, etc)
But I just set it where I am comfortable. a simple finger swipe to raise or lower a few degrees, or swipe all the way down to lower it to my minimum setting......when I go away. Which is 65. Usually keep it 67-68 at night....and 69-70 when home.
So not sure how it saves me money.
but a few reasons I choose the ecobee.....
It is WIFI, meaning I download their app and I can control the t-stat from my phone. If I turn it down to 65 when away.....I can turn it up an hour or so before I get home. No big deal here as many t-stats have this feature.
One thing it had that others didnt was the ability to control the second stage on my geothermal. Meaning when it comes on or goes off. Alot of other t-stats didnt have this. Had basic setting where you could choose mild, moderate, or agressive for temp control. Agressive meaning 2nd stage runs more as it tries harder (and quicker) to get to the setting you put it at. Or mild where it wont try too hard or run second stage unless 1st stage just flat cannot keep up. Them moderate somewhere in between.
The ecobee gives me alot more control. I can choose a degree swing before 2nd stage kicks in.....like if I call for more than a 3* change.....just forget 1st stage and go right to second. Or I can choose a time....like if 1st has ran for more than 90 min then go ahead and use second stage, etc.
Same way with temp swing. Alot of t-stats wouldnt let this change. ecobee can,
   / Heat Pump and power consumption #82
I keep our heat set on 68 day and night with a Heat Pump. I don't really see a need to change the temperature wildly when I'm at work. As others have stated a heat pump has a hard time with those big changes in settings without using aux heat, whether it be propane, heat strips or what. We also use a small space heater in the living room to take off the chill if needed. I also use a Honeywell WiFi Thermostat that can be controlled via an app or through Alexa. However, I rarely change it when I'm away. I also use the Honeywell outside temperature probe instead of the sensor in the outside unit, it gives you a truer reading of outside temp.
   / Heat Pump and power consumption #83
LD1, it saves money because I can turn it down from anywhere in the world. Then, turn it back to comfortable a few hours before we get back. It save alright.
   / Heat Pump and power consumption #84
I understand that. But there are MANY MANY wifi thermostats out there that allow this.
The ecobee claims it is better than the rest because of its "learning" habits over time. That is what I dont buy into.
I choose the ecobee because it gave me the greatest control over my equipment. AND.....I forgot to mention earlier......I can go online and see run-time charts. See just how long my system runs in a given day or month or whatever. And being wifi....connected to web......I can also correlate that runtime to whatever outdoor temps (and wind speeds) were at the time.
Dont know my actual numbers....but for example....I can look and see that at 30* outside and 10mph wind......my unit will run for say 40 minutes then shut off for 30, back on for 40, etc.
At 20 degrees and 10mph wind......maybe on for 50 off for 20........or if wind is only 5mph.....maybe on for 45 off for 25...
Alot more information at my fingertips than the average person probably cares about or even understands. But I like it.
But the "learning algorithms"....that save even more........not really sold on all that jazz
   / Heat Pump and power consumption #85
I like the ecobee because you can view the runtime from your computer and see how long second stage is running vs. first stage. My geothermal ran with out using auxiliary when it was -18 earlier this winter and second stage was running non stop for most of the day.
   / Heat Pump and power consumption #86
Sound like your system is sized about perfectly
   / Heat Pump and power consumption #87
I installed a Johnson Control Optimum Start/Stop system in the Hospital about 20 years ago...
It controls 24 devices... a large 100% outside air built up unit and numerous package units, etc...
The optimum start/stop "Learns" when the unit has to start depending on desired in door temp relative to outside temp.
When it is 100 outside the unit may never shut off because it has learned to maintain the indoor temp it can't.
On Fridays I might have it programmed to shut down or go to after hour temp at 5 pm... but the unit will stop cooling or heating as much as 30 to 40 minutes prior if it has "Learned" the desired temp will be still met at 5 pm... so it coasts into closing time.
It really does work very well and changing Holiday Schedules are a breeze...
Where it really shines is in diagnostics... it will show real time supply and exhaust air... which allows me to zero in of a problem...
   / Heat Pump and power consumption #88
I'm still goofing around with my Nest. I have mine set to 68deg day and 62 at night. My wife and I do not have a regular home/away schedule but it recognize when our phones leave and are getting close to home and it turns on/off between 62/68 based on phone GPS. I can set the ECO setting to whatever.
I am sitting in my hotel room a 1000 miles away and just took this screen shot of some history. Still digesting. I have a heat pump and air handling system. No idea yet on setting for ultimate efficiency.
Yes, I can also control my thermostat remotely or change program, yada, yada, yada.
   / Heat Pump and power consumption #89
I assume the orange bars mean its running?
Anyway to see how long it ran for....other than guessing by how long the bar is?
How far back can you view historical data? just the 5 days shown?
Is it a single stage or two stage system? And if 2, does it indicate something different when second stage comes on?
   / Heat Pump and power consumption #90
I'm still trying to figure out just what I have... and whether I set up the thermostat right. On a plane heading home so more detail later. But to answer your question on the graph... no this is all the detail I get... at least on Nest.com online. I have data from yesterday going back to the 16th. I have the schedule set at 68 at 9am and 62 at 10pm.
In the evening we turn on our propane fireplace insert so that is the reason for lack of heating activity then.
   / Heat Pump and power consumption #91
I'm very familiar with JCI. Most of the technology you've mentioned per your JCI system, Lennox, Trane and Carrier have incorporated into thier residential higher end systems today.
Just remember, when talking about actual ROI, even today with 14 SEER being the minimum, anything over 16 SEER with multi stage or inverter compressors, you're paying for the "comfort".
I consider myself pretty familiar with t-stats, and although I had the newest and greatest put on my walls about 7 years ago, give me an arrow with up and down per temp control, and I just leave it set. I do enough with my phone that I don't want to have to control my thermostat LOL
   / Heat Pump and power consumption #92
On my own home I have a mercury stat that is circa 1960.... it has been flawless.
Some of the homes around here have millivolt heaters... even central furnaces... the new stats with contact points don't hold a candle to the mercury stats...
The county low income energy assistance program changed out all the stats and some light fixtures... the stats stop working if the battery is low... so it generates a service call... the light fixtures require $9 bulbs and no tenant has yet to buy one...
   / Heat Pump and power consumption #93
Isn’t our government great? Light fixtures have non-standard bulbs?
   / Heat Pump and power consumption #94
The local Lowe’s doesn’t have 100 watt light bulbs unless you want to buy one of the $9 3 way lamp bulbs with the high setting being 100 watt. I deal with the problem by just using a $2 150 watt bulb.
   / Heat Pump and power consumption #95
98% of residential bulbs were the same... with a few small candelabra added...
With the mandate for energy efficiency this has all changed... as has pricing.
I could buy a box of 8 60W or 75W bulbs for $1.99 and used them for the rentals...
Now there are so many variations and even then there are 2 pin, and 4 pin and circle, u-tube, etc...
Tenants simply refuse to buy any of the Energy Efficient Bulbs...
One of my manager friends had a new building with LED and the entire building was stripped of bulbs... who would have thought stealing light bulbs worthwhile?
   / Heat Pump and power consumption #96
FYI when it comes to the HVAC industry and government guidelines, we can mostly blame California.
Another news flash, there are govenment programs out there across the nation that allow for free HVAC systems for people that can't afford it. It's actually pretty big business here in NC. Don't get me going on that one.
That reminds me of this.. My uncle was going into town near Elizabeth City, NC for a family reunion (in August?) 5-10 years ago. He stopped at my grand-aunts house a couple hours before the reunion. She was in her 80s at the time. Once it was time to head to the reunion, she started opening a few windows. My uncle said, shouldn't we turn the air conditioner on? She replied, what do you think I'm doing...
   / Heat Pump and power consumption #98
I get so tired of these handout programs. A hand up program is what this country should be about, a hand out program is socialism.
   / Heat Pump and power consumption #99
LD, what does the Ecobee data output look like?
Nest.com shows me just last 10days history. No way to tell run time except daily total. The previous screen capture I posted was expanded data for each day by clicking on the bar. Here is the overview graph.
   / Heat Pump and power consumption #100
Here is the online chart. Can go back a long time. Or zoom in for finer detail
Here is a monthly runtime total
Or I can download all data to a spreadsheet for any given range
And here is what that looks like. Had to shrink it down to show it all. It is blocked in 5 min increments. Where it says heat stage...(there is 1st and second but got cut off)......that is the runtime in that 5 min block (in seconds).
So I can take that information for a whole day......just highlight all the cells and give a sum......and I know exactly how long down to the second....that my unit has ran for a day. And knowing its amp draw.....I can compute heating cost. And I can also average out the daily wind speed and temp. So what I have done over a few months after I got the stat......was make a spreadsheet of various outdoor temps and wind conditions and correlate that to a cost to heat my house.
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
SKYJACK SJIII 3219 SCISSOR LIFT (A60429)
SKYJACK SJIII 3219...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
