Hearing Protection
/ Hearing Protection #1
Grrrr
Platinum Member
Devon, UK
John Deere!
Does anyone else wear any sort of ear protection when operating their tractor. I was reading through the manual that came with our ride on mower and it said you should always wear hearing protection with it.
I know that some of our tractors are pretty loud especially at PTO speed. I always have ear defenders close by especially when I'm spending a long time on the tractor.
Back in the 1976 a rule was enforced that in the UK all cabbed tractors had to have an in cab noise level of less than 90 db. Are there any noise reestrictions on todays CUT's and SUBCUT's?
/ Hearing Protection #2
Always - I always wear hearing protection while running small engines. That means tractors, lawn mowers, chainsaws, motorcycles, weed whackers, snow throwers etc. You only have two hearing transducers and they have to last a lifetime.
Anecdote - A long time ago I bought a small biplane with an 85hp unmuffled engine. I remember taking it up for the first time and having lots of fun. But when I came back down I remember that my ears rang for a bit. The next day I did it again and my ears rang for about three hours. The following day, being naturally dumb, my ears rang for three days. I only had to be hit on the head three times to get the point.
The muffs are the easiest to use but they are the most inconvenient and sometimes hot. I like the foam ear plugs that you can buy at HD in large quantities. I find that I can carry on most conversations without removing them.
/ Hearing Protection #3
Grrrr:
Always wear ear protection. At minimum get NRR29 rated foam ear plugs; more is better. I will often wear foam ear plugs as well as over the ear "muffs" especially for extended use of my tractor at PTO RPM speeds. Jay
jbrumberg said:
Grrrr:
Rest assured, I always do when working for any lengt of time on the tractor. I was just wandering what other peoples thoughts were on it but by the looks of it lots of people do.
/ Hearing Protection #5
Yep, ear plugs when I'm on the tractor (especially if running a mower or cutter) and when I'm pushing the lawn mower.
/ Hearing Protection #6
You bet, foam earplugs while on the tractor, muffs and sometimes muffs and foam plugs while using riding lawn mowers, mush mowers and string trimmers. It may be just my imagination but I don't seem to feel as tired after a day of using these things if I wear hearing protection. What does everybody else think?
/ Hearing Protection #7
EdC:
I agree with you as to longterm exposure to noise increasing fatigue. I reason :confused: that high volume noise increases stress levels which increases fatigue IMHO. Jay
/ Hearing Protection #8
I am glad you mentioned that Ed. Several years ago it took 2 hours to mow with my X495 and I would be dog tired. Then one day I put on the ear muffs and couldn't believe how much better I felt afterwards. I have been wearing them ever since.
/ Hearing Protection #9
Grrrr said:
Does anyone else wear any sort of ear protection when operating their tractor?
WHAT? WHAT DID YOU SAY? I DIDN'T QUITE HEAR YOU... :D
Yes, I wear hearing protection whenever I'm running any sort of loud machinery. I've nearly worn out my AO Safety "Worktunes" but I use foam plugs at times since the headphone don't fit with wide brimmed hats.
It's nearly impossible to have a normal conversation with some of my older relatives without raising my voice to near the point of shouting. Since I've got damage in one ear from shooting guns more than 20 years ago, I'd like to maintain what I have now for at least another 50 years. ;) I'm reminded of the value of wearing hearing protection on those occassional times where I don't wear plugs/headphones for a short amount of time, and my ears are ringing afterwords.
Back to original question, are there any noise restrictions on CUTs? I imagine there are, but I would also imagine that the restriction is still higher than a safe level of noise exposure.
/ Hearing Protection #10
Bad news !!!
You're wrong
The manual is wrong
He's wrong
I'm wrong
Your thread got me curious so I went looking for my sound pressure level meter and did a few measurement:
In the following listing, some readings are typical and are published. And some are my measurements. You'll know which is which.
10db threshold of hearing
50db speech
64db measured roadside traffic noise at 50 feet
70db vacuum cleaner at 10 feet
74db measured miata convertible top up
74db measured JD2320 stationary and idling at 1500rpm
80db heavy traffic
84db measured miata convertible with top down
85db tractors with soundproof cabs
85db measured JD2320 stationary idling at 3000rpm
99db measured weed whacker
100db tractors w/o soundproof cabs and farm machines
120db chainsaw and jackhammer
130db jet takeoff at 200 feet
140db threshold of pain
And here's another listing on permissible sound level exposure from the U.S. Department of Labor
8 hours 90db
6 hours 92db
4 hours 95db
2 hours 100db
.25 hours or less 115db
So, looking at the above data leads one to the conclusion that it is not necessary to have ear protection on the JD2320 even operating at maximum rpm. Also I should not exceed 2 hours per day weed whacking without protection. As for the chain saw, protection is mandatory.
There's nothing that spoils a good argument than data and facts.
As for me - I'll continue to use ear protection for all my small motors including the tractor.
/ Hearing Protection #12
all i use now is muffs cause i was weed wacking last summer,wear those foam ear plugs the throw away kind, and was walking backwards, (i know its my own stupid fault). there was a tree branch and it pushed the foam plug into my ear canal, now talk about pain. i was down instantly and hardly could walk the 100 feet to the house to get sommone to take me to the docter cause i couldnt/didnt want to take it out myself. ever sense then ive sworen i wont wear plugs, muffs all the way for me.
Mark
/ Hearing Protection #13
Unfortunately, I have suffered hearing damage. It crept up on me during the last 5 years. I think most of mine is due to air ratchets and air hoses. I also like racing but have worn hearing protection at them for the last several years. My ears ring constantly and is above all other normal noises. When I go to the local dirt tracks or to NASCAR events, I see almost nobody wearing hearing protection. I can see a class action lawsuit against racing bodies some day. I was warned by a high school teacher who flew bombers during WW two that suffered hearing damage from the planes. Did not think it would happen to me but here 30 years later it has happened. Anyway, I always wear hearing protection now to save what is left.
/ Hearing Protection #14
972500 you were extremely lucky that you had that foam ear plug. Otherwise that branch would have gone up your ear canal.
In the prohibition era there was a hitman that specialized in icepick-in-the-ear murders. He would typically find his victim drinking in a bar, walk up to him and throw an arm around him. His hand had the icepick that would go in the victim's ear. The victim died instantly and there were only a few drops of blood. As the victim slumped, the mobster would say that he's had too much and had fallen asleep. Then he would offer to take him home. The other customers and the barkeep never realized that he had been murdered.
Of course you would have been luckier if you had been wearing earmuffs.
I carry a pair of foam plugs in a small container in my coat pocket. Sometimes when I'm in a restaurant and there's a noisy child in the next booth, I just put them in.
In Pennsylvania it's illegal to wear earphones, muffs or other protection while driving. This is a problem for motorcyclists with loud mufflers that want to keep their hearing. However if the policeman notices the ear plugs, the motorcyclist innocently says, "They're noise filters officer"
/ Hearing Protection #15
I like my Peltor H10 muffs, which have an NRR of 30db.
In ther warm weather they make you heat up quicker, though. I use them chainsawing & shooting year-round, and doing any other VERY loud things.
In summer, for less painful noises, like the tractor, I'll go with the baffle plugs that are connected together with the little plastic cord, I find when i remove them I can drape them aroud the neck for a short bit, then have them "around" when it's time to resume.
I do keep some of the little foamie plugs around, here and there, good back-up, because we often use what we have readily available.
Gas powered riding mowers, especially older ones, will just about make you go deaf.
/ Hearing Protection #16
Oh Man! I love my Peltor worktunes muffs. Not only does it block out the extrem noise of the mower and high rpms, I also enjoy a couple of hours of "tractor boogy". :)
/ Hearing Protection #17
yea i deffintly realzie i was lucky to have the plugs rather than nothing as it would have went into my ear. but as u stated had i had muffs on it simply would have deflected off and i wouldnt have knowen a differnece.
Mark
/ Hearing Protection #18
I only use muffs. Too help prevent them from getting funky with skin oil and sweat, I put Kleenex over the opening for each ear, pushing in the center (a place for the ear) and put them on (which means one ear at a time if you've ever tried doing this. I've gotten good at it over the (y)ears). Not particularly useful if you are constantly putting them on and taking them off, but I don't generally do that so it works for me.
/ Hearing Protection #19
I am afraid to look too closely at my ear muffs. I guess they would probably meet the standard of "funky"; but I am the only one wearing them, and they work. Now my foam ear plugs- they are funky :eek:. Jay
/ Hearing Protection #20
Take it from someone with a substantial high frequency hearing loss (22 years in the USMC when "real men didn't plug their ears" and a familial history of otosclerosis), protect your hearing. Even if the noise level is below someone's standards! I'm a bit surprised by the law prohibiting ear protection while driving ... deaf people are permitted to drive ... in fact back about 20 years ago, we had a new civilian draftsman at a Marine Corps Base and since my son is deaf I sign and got to be friends with him. Base motor transport refused to give him a license for a government vehicle because he was deaf even though the base order said all he needed was a valid state license which he had. I talked to the motor transport officer and asked why? He said, "because he can't hear emergency vehicles coming." I responded that we make heavy equipment operators wear hearing protection while they drive including on base roads and that Lance Corporal with the new Camaro, windows rolled up, a/c on, and the 2 megawatt stereo blaring -- well how much siren could either of them hear? He got his base license.
Unused 2023 Monroe-Tufline DS1144T 12ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2021 CATERPILLAR 316FL EXCAVATOR (A65056)
2021 CATERPILLAR...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
2012 MACK GRANITE-GU713 (INOPERABLE) (A67714)
2012 MACK...
