Heads up for 47" snowblower users..
/ Heads up for 47" snowblower users.. #1
ChuckinNH
Elite Member, R.I.P.
NH
(B2620, had BX22) Simplicity Legacy w/48" mmm
I was at a local Kubota dealership yesterday ( yes, I know...... but I was actually there buying parts for my Simplicity). Anyway, they had a B2920 in the showroom with a snowblower mounted on it. The snowblower was fitted with extension plates to widen the front of the snowblower 2"-3" on each side, and were high enough to act as drift knives. They bolted to the sides of the snowblower with three bolts, and to the lip on the top of the snowblower using a right angle bracket, and a couple of smaller bolts. I don't remember them being part of the stock snowblower package, but they sure looked like they would fit right on to a JD snowblower too, and provide a ready made solution. Hope this helps someone.
/ Heads up for 47" snowblower users.. #2
Thanks Chuck. I have a 47 blower from my 2320 but haven't used it on the 2720 yet. I think the rear track is a bit wider but don't know if this will create problems. It worked perfectly with the 2320 and I never needed chains although I do use a rear box that is loaded with concrete.
3 ROLL TOOL CARTS (A67714)
3 ROLL TOOL CARTS...
2027 . . (A67714)
2027 . . (A67714)
Set of 4 Unused 12-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
Hensley 16in. Bucket with Teeth Excavator Attachment (A68183)
Hensley 16in...
Dewalt DG6000 6000W Portable Gasoline Generator (A66734)
Dewalt DG6000...
