headlight switch
/ headlight switch #1
henrysMFGC2310TBL
Bronze Member
Carleton Place, ON
JD D140
2310, for a while I had to wiggle the switch lever to get the headlights to work. The other day they did not work but the tail and gauge light I installed did work. So here I am thinking I will have to wire in a toggle sw and bypass the MF switch but then I took the MF switch apart and it was corroded inside, so it is now cleaned up lubed with dielectric grease and works great.
/ headlight switch #2
Yep, had just the opposite prob, my h-lights and tail lights worked but the dash didn't. Same thing corrosion, cleaned and greased, now works.
/ headlight switch #3
My problem is the left turn signal doesn't work but it works when you put on the 4 way flashers.:confused2:
/ headlight switch #4
Mine does the same thing occasionally. I haven't checked into it yet, but I'm sure it's in the switch.
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2022 EZ-GO ELITE...
10in Bucket w/ Teeth Excavator Attachment (A64194)
10in Bucket w/...
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
