headlight switch
/ headlight switch #1
henrysMFGC2310TBL
Carleton Place, ON
JD D140
2310, for a while I had to wiggle the switch lever to get the headlights to work. The other day they did not work but the tail and gauge light I installed did work. So here I am thinking I will have to wire in a toggle sw and bypass the MF switch but then I took the MF switch apart and it was corroded inside, so it is now cleaned up lubed with dielectric grease and works great.
/ headlight switch #2
Yep, had just the opposite prob, my h-lights and tail lights worked but the dash didn't. Same thing corrosion, cleaned and greased, now works.
/ headlight switch #3
My problem is the left turn signal doesn't work but it works when you put on the 4 way flashers.:confused2:
/ headlight switch #4
Mine does the same thing occasionally. I haven't checked into it yet, but I'm sure it's in the switch.
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A67147)
2012 FREIGHTLINER...
2010 ALTEC DIGGER DERRICK (A67148)
2010 ALTEC DIGGER...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
1996 Polar DOT 407 Single Comp Insulated Diesel Trailer (A64194)
1996 Polar DOT 407...
1062 (A63291)
1062 (A63291)
