headlight switch
/ headlight switch #1
henrysMFGC2310TBL
Carleton Place, ON
JD D140
2310, for a while I had to wiggle the switch lever to get the headlights to work. The other day they did not work but the tail and gauge light I installed did work. So here I am thinking I will have to wire in a toggle sw and bypass the MF switch but then I took the MF switch apart and it was corroded inside, so it is now cleaned up lubed with dielectric grease and works great.
/ headlight switch #2
Yep, had just the opposite prob, my h-lights and tail lights worked but the dash didn't. Same thing corrosion, cleaned and greased, now works.
/ headlight switch #3
My problem is the left turn signal doesn't work but it works when you put on the 4 way flashers.:confused2:
/ headlight switch #4
Mine does the same thing occasionally. I haven't checked into it yet, but I'm sure it's in the switch.
ELECTRIC CHAIN HOIST (A64278)
ELECTRIC CHAIN...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
Year: 2017 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 154,595 Plate: (A64557)
Year: 2017 Make...
More info coming soon. (A64557)
More info coming...
