headlight switch
/ headlight switch #1
henrysMFGC2310TBL
Carleton Place, ON
JD D140
2310, for a while I had to wiggle the switch lever to get the headlights to work. The other day they did not work but the tail and gauge light I installed did work. So here I am thinking I will have to wire in a toggle sw and bypass the MF switch but then I took the MF switch apart and it was corroded inside, so it is now cleaned up lubed with dielectric grease and works great.
/ headlight switch #2
Yep, had just the opposite prob, my h-lights and tail lights worked but the dash didn't. Same thing corrosion, cleaned and greased, now works.
/ headlight switch #3
My problem is the left turn signal doesn't work but it works when you put on the 4 way flashers.:confused2:
/ headlight switch #4
Mine does the same thing occasionally. I haven't checked into it yet, but I'm sure it's in the switch.
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
