HEAD GASKET
/ HEAD GASKET #1
JMF39870
NEWTON,GA
JOHN DEERE 1250
DOES ANY BODY KNOW WHERE I CAN GET A HEAD GASKET FOR AJOHN DEERE 1250--YANMAR PART #121850-01320 OR JOHN DEERE PART #CH16706 -----JOHN DEERE OR YANMAR SEEMS TO BE ABLE TO HELP ---ENGINE IS A YANMAR 3T951--------
/ HEAD GASKET #2
Have you contacted Hoye Tractor to see if they know the one that fits? I see they list a 1250 but only have a few parts listed in the JD section.
/ HEAD GASKET #4
If there able to help i would call them?
If you left out a word and there NOT able to help i would try HOye like was suggested.
I think this is the second Head gasket post of the summer, seems were doing good in this extreme heat this year!
/ HEAD GASKET
THEY DID NOT HAVE IT ---I DID FIND IT AT DEMOTT TRAC IN MOULTRIE GA --THANKS
/ HEAD GASKET #6
Is your tractor equiped with a raidiator? if so you may be able to fix a head gasket w/o taking it apart. This has worked for me several times and also with people I've recommended it too. At the Auto shop/walmart/Auto Zone/ Advanced they sell a product called'' Block Seal'' it sells for about $12-14 and follow the instructions on the to the letter, it works every time I've tried it. Good luck
/ HEAD GASKET #7
That stuff is also a good way to plug up your radiator or something else like cooling passages. If it was a complicated engine in a car to get out and not worth much i might try it. But not on a tractor where the engine is so easy to work on.
/ HEAD GASKET #8
worked on my Porshe, did not cost $2000,00, still running in it today. oh well , what works you, sorry,
/ HEAD GASKET #10
Gee, you don't know Porsche made water cooled engines?, sorry I replied to this problem, Yes Porsche makes Water cooled engines, Try that thing called the internet, look up "PORSCHE" . Or just stick to tractors, yup that works for me.
/ HEAD GASKET #11
924 and 928 come to mind...I am sure not a euro tech. remember Risky Business with that weirdo Tom Cruise?
fwtw I still wouldn't use the stuff but happy it worked for someone replacing the hg is the best way you may have a warped head only way to know is pull it and do the valves while you have it down. ;)
/ HEAD GASKET #12
I need a ch16706 Gasket for a 1250 jhon deere tractor do nyou happen to have any? give me your contact number so I can call you.
/ HEAD GASKET #13
Not sure where you are located at but COntact Danny PArker of Parker equipment ( dparker@peq.com ) I purchased a head gasket from him on August 30th he QUICKLY had in in the mail & I got it on the 1st. I wasn't expecting it till ATleast Tuesday (since Monday was a holiday. BTW he's a Yanmar Dealer in AL. :thumbsup:
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A68842)
TIRE RACK WITH...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
Ford 340B Loader Attachment
Ford 340B Loader...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
