HEAD GASKET
/ HEAD GASKET #1
JMF39870
NEWTON,GA
JOHN DEERE 1250
DOES ANY BODY KNOW WHERE I CAN GET A HEAD GASKET FOR AJOHN DEERE 1250--YANMAR PART #121850-01320 OR JOHN DEERE PART #CH16706 -----JOHN DEERE OR YANMAR SEEMS TO BE ABLE TO HELP ---ENGINE IS A YANMAR 3T951--------
/ HEAD GASKET #2
Have you contacted Hoye Tractor to see if they know the one that fits? I see they list a 1250 but only have a few parts listed in the JD section.
/ HEAD GASKET #4
If there able to help i would call them?
If you left out a word and there NOT able to help i would try HOye like was suggested.
I think this is the second Head gasket post of the summer, seems were doing good in this extreme heat this year!
/ HEAD GASKET
THEY DID NOT HAVE IT ---I DID FIND IT AT DEMOTT TRAC IN MOULTRIE GA --THANKS
/ HEAD GASKET #6
Is your tractor equiped with a raidiator? if so you may be able to fix a head gasket w/o taking it apart. This has worked for me several times and also with people I've recommended it too. At the Auto shop/walmart/Auto Zone/ Advanced they sell a product called'' Block Seal'' it sells for about $12-14 and follow the instructions on the to the letter, it works every time I've tried it. Good luck
/ HEAD GASKET #7
That stuff is also a good way to plug up your radiator or something else like cooling passages. If it was a complicated engine in a car to get out and not worth much i might try it. But not on a tractor where the engine is so easy to work on.
/ HEAD GASKET #8
worked on my Porshe, did not cost $2000,00, still running in it today. oh well , what works you, sorry,
/ HEAD GASKET #10
Gee, you don't know Porsche made water cooled engines?, sorry I replied to this problem, Yes Porsche makes Water cooled engines, Try that thing called the internet, look up "PORSCHE" . Or just stick to tractors, yup that works for me.
/ HEAD GASKET #11
924 and 928 come to mind...I am sure not a euro tech. remember Risky Business with that weirdo Tom Cruise?
fwtw I still wouldn't use the stuff but happy it worked for someone replacing the hg is the best way you may have a warped head only way to know is pull it and do the valves while you have it down. ;)
/ HEAD GASKET #12
I need a ch16706 Gasket for a 1250 jhon deere tractor do nyou happen to have any? give me your contact number so I can call you.
/ HEAD GASKET #13
Not sure where you are located at but COntact Danny PArker of Parker equipment ( dparker@peq.com ) I purchased a head gasket from him on August 30th he QUICKLY had in in the mail & I got it on the 1st. I wasn't expecting it till ATleast Tuesday (since Monday was a holiday. BTW he's a Yanmar Dealer in AL. :thumbsup:
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
TWO PALLETS OF HOSES AND EXTENSION CORDS/LIGHTS (A67714)
TWO PALLETS OF...
2016 JOHN DEERE 331G SKID STEER (A65056)
2016 JOHN DEERE...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
