Haying Pictures . . .
/ Haying Pictures . . . #1
mark.r
Platinum Member
Leesburg, VA
Kioti DK45SE
With the weather finally starting to become more enjoyable and bearable for that matter and finally being able to get some seed, fertilizer, etc. spread I am starting to get spring/summer fever. I was online looking at some haying pictures and found some pretty neat ones. I was REALLY impressed with these guys operation. I can't imagine the money that goes into some of these setups.
/ Haying Pictures . . . #2
I see you found Josh's pictures. Did you see the pics from when he rolled that large square baler over?
Not yet, I am still going through them as we speak. I am simply in awe. They get better the further I get into them. This is good stuff. One question I do have, are those the OEM tires on that JD 7630, or are they an cost option? They look enourmously wide versus the 7630's listed for sale on Tractorhouse.
Here something you don't see everyday . . .
/ Haying Pictures . . . #5
They look like a standard tire choice. If you are in a row crop area you most likely will see narrower tire options on the tractors.
Ok, I am assuming I was seeing a row crop set up as they were very narrow. That said, I REALLY like these BIG wide AG tires . . . until I have to replace them.:D
I never did find this picture, do you know where to find more. I love his operation!
/ Haying Pictures . . . #10
I think he is driving backwards. Aggie doing this baling?
D.
/ Haying Pictures . . . #11
If these pics don't get you chomping at the bit to get out in the hay field there must be something wrong with you. Or maybe you're just sane unlike some of the rest of us!
I can never tell if those TV's are going forward or backwards.;)
/ Haying Pictures . . . #13
Great photos! As soon as I saw all those "Quakies" and the white Spruce in the pics I knew it was from somewhere NORTH...
They sure got some big Hosses to put up hay with --- but workin' with those big cubes and big rounds; ya' gotta have some heft to your machine!
Sure does make me wish for some dirt --- any dirt will do at this point!!
Thanks.
AKfish
/ Haying Pictures . . . #14
Thanks.
AKfish
They were using tractors bigger then needed on a lot of the equipment because they had that size tractors available to use. Two examples are the Ford 7710 on the wheel rake and TV145 on small square baler.
Mark, I will look for the pic if I can't find it I will ask Josh for a copy and post it for you.
Thanks Robert, please do. Please tell him I love his pics. I was wondering if that 7710 was similar to yours . . . other than yours being a 7710-II. Did the 7710-II's come in FWD as well?
As far as HP requirements I would agree, if you that's what you have use it. I would assume the big square baler takes quite a bit of hp though.
/ Haying Pictures . . . #16
Their 7710 is also a II (I forgot to write it down). This is the first year they did hay so they were using the tractors they had available and learning as they go.
/ Haying Pictures . . . #17
Yeah, Josh has some nice pics. The tires on the JD are Michelin XM108, I think, radials for sure. Another album to check out is (Gerard's) FlyingDutchman's album. Some awesome forage pics in his.
I'm diggin' those Michelins:D , are they an OEM tire for multiple manufact.?
Do you have a link for FlyingDutchman's album?
Cub Cadet Pro Z 972 (A64127)
Cub Cadet Pro Z...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
