Hay wagons; let's see them!
   / Hay wagons; let's see them! #131
Thought I would throw in my hay wagon rebuild from this summer. I picked this "Electric ...." wagon running gear for $150 with froze spindles. I ended up splitting the spindle housings with 4 1/2" angle grinder and cut-off wheel. Then cleaning up the spindle shaft , then rewelding the spindle housing . Straightened the tierod , lengthened the wagon to 16' , it is my intention to use for hayrides .
Wood from a neighbors removed pool deck ... 2 x 6 treated. Main rails 2 x12 treated.
   / Hay wagons; let's see them! #132
Very nice! The kids (young and old) ought to enjoy that ride.
   / Hay wagons; let's see them! #133
Great project and great hay wagon.
   / Hay wagons; let's see them! #134
Nice job. Did you paint the tractor too? I don't see any decals on it. Is it a WD?
   / Hay wagons; let's see them! #135
Thanks, yes it's a WD . Been working on restoring it for about a year now. I painted the wagon first , then
the tractor . I still have the fenders, rear hitch and loader to paint
   / Hay wagons; let's see them! #136
Nice job on the wagon and the tractor.
   / Hay wagons; let's see them! #137
My hay wagon is an old David Bradley sold by Sears and Roebuck... 1950's.
mark
does you wagon have spoke rims. I have a Sears wagon that has spoke rims but I can not remove hubs. The hubs have peru on them with two slots on front. any help
will be greatly appreciated
   / Hay wagons; let's see them! #138
ACBilly---what size tires did you put on that? It has a nice low-boy look to it. Really good job.
   / Hay wagons; let's see them! #139
I have the same Peru hubs on an old Sears running gear. The cast Peru marked hub cap just threads off. Put a drift pin against the side of the slot and tap with a hammer in order to break the hub loose. Inside is conventional tapered roller bearing arrangement with slotted nut to adjust the bearings.
I've just recently taken mine apart. I didn't find any inboard wheel seals. I wonder if they had seals? Just O-rings in the grooves on the spindle shoulder?
   / Hay wagons; let's see them! #140
That's cool!
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
