Hay wagons; let's see them!
   / Hay wagons; let's see them! #121
Storage for straps to tie down the load. Frame is built for 14 metric tons
14 tons of hay?
Is that hand loaded from the ground? How heavy of bales?
It looks like it also has a lot of tongue weight.
Clifford - I'll let Tor answer, but my experience in Germany, Switzerland, and communication with Massey owners in England, it seems like they tend to use trailers with a lot more tongue load than we typically use here. Not sure why.....?
   / Hay wagons; let's see them! #123
Trailer frame was meant to another use but after that need changing so I used what I had. Hay bale weighs about 35kg apiece. And drawbar weight helps with getting traction, trailer has hydraulic brakes that are connected to the brake system of the tractor. Where I live we use a different type of hitch than in the United States. trekk.jpg
   / Hay wagons; let's see them! #124
Looks like what would call a pintle hitch.
   / Hay wagons; let's see them! #125
we call it a pickup hitch, the beauty of it is that one can connect to a trailer without leaving the tractor. release the lock, drop it down, back the tractor till eye on the trailer and lift up the hook then everything is ready to run
   / Hay wagons; let's see them! #126
So, about 77lb bales.
Still, say 10,000kg / 35kg = 285 bales... that would be a big load. But, still good for a "repurposed" trailer frame.
I presume the tractor can take a fairly heavy load, especially with the pintle hitch mounted to the differential.
As far as wheel location, I guess it would depend on a number of factors, especially where it is used and what is towing it. Here in the USA, just about anybody with more than 1 acre owns a pickup which does best with less than 1000lbs or so of tongue weight. A truck, of course, might be designed for much more tongue weight (usually 5th wheel). Around the farm with the tractor, it probably does well with that setup, and undoubtedly helps with traction.
   / Hay wagons; let's see them! #127
Trailer frame was meant to another use but after that need changing so I used what I had. Hay bale weighs about 35kg apiece. And drawbar weight helps with getting traction, trailer has hydraulic brakes that are connected to the brake system of the tractor. Where I live we use a different type of hitch than in the United States.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=328717"/>
I will want one!
And there lies the big difference. When I've been in Europe, you rarely see a pick-up. Most farmers drive their tractors on the roads much more and much further than we do. My buddy who lives in Germany says it's something to do with taxes....? It's cheaper to register a tractor than a truck of comparable hauling capabilities.
   / Hay wagons; let's see them! #129
Many farmers have pickup truck here too, but rarely anything larger than a Toyota hilux due to road tax. I pay about 1000USD per year in road tax on the hilux, almost 800USD in insurance and I pay a little over 8.5 USD for a gallon of disel. Lorries were more common for farmers before, but because of the tax is almost no one bother with it now. And we have much stricter rules about how much weight we can tow with a car / pickup
I knew it was something like that! ;)
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2012 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2012 Vantage...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
2013 International WorkStar 7400 Altec D3060ATR Insulated Digger Derrick Truck (A55973)
2013 International...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
