Hay Elevator I.D.
/ Hay Elevator I.D. #1
Firecreekstables11
2019 Kubota 6040
Greetings People,
I have a Hay Elevator that I'm trying to get up and running. I need some help to identify the make and model poss. years it was made.
Thanks in advance,
Michael
/ Hay Elevator I.D. #2
I assume that you planned to attach some photos to that post??
/ Hay Elevator I.D. #3
Was it silver? Long and narrow? I think it was made in the 20th century, likely the last half...
Carnac the Magnificent
/ Hay Elevator I.D.
I will take a pic tomorrow that is smaller so that it can load
/ Hay Elevator I.D. #6
You can open photos in Microsoft Paint and resize them using the resize command and try 25% or less to reduce the file size.
/ Hay Elevator I.D. #11
I have seen one of those before, but I do not recall the make. It was probably made in the 1950's.
/ Hay Elevator I.D. #12
There not really much to them, most of the part can be found at a Tractor Supply or a similar store. You can also get a lot of bearings and power transmission component at Surplus Center online. What specifically is wrong with it?
New Holland TS6030 (A64911)
New Holland TS6030...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A68183)
2023 Caterpillar...
2013 BIG TEX T/A UTILITY TRAILER (A67714)
2013 BIG TEX T/A...
Survey Kit (A64912)
Survey Kit (A64912)
Kivel QA Pallet Forks (A64912)
Kivel QA Pallet...
