Hay Elevator I.D.
/ Hay Elevator I.D. #1
Firecreekstables11
2019 Kubota 6040
Greetings People,
I have a Hay Elevator that I'm trying to get up and running. I need some help to identify the make and model poss. years it was made.
Thanks in advance,
Michael
/ Hay Elevator I.D. #2
I assume that you planned to attach some photos to that post??
/ Hay Elevator I.D. #3
Was it silver? Long and narrow? I think it was made in the 20th century, likely the last half...
Carnac the Magnificent
/ Hay Elevator I.D.
I will take a pic tomorrow that is smaller so that it can load
/ Hay Elevator I.D. #6
You can open photos in Microsoft Paint and resize them using the resize command and try 25% or less to reduce the file size.
/ Hay Elevator I.D. #11
I have seen one of those before, but I do not recall the make. It was probably made in the 1950's.
/ Hay Elevator I.D. #12
There not really much to them, most of the part can be found at a Tractor Supply or a similar store. You can also get a lot of bearings and power transmission component at Surplus Center online. What specifically is wrong with it?
