Hay Elevator I.D.
/ Hay Elevator I.D. #1
Firecreekstables11
2019 Kubota 6040
Greetings People,
I have a Hay Elevator that I'm trying to get up and running. I need some help to identify the make and model poss. years it was made.
Thanks in advance,
Michael
/ Hay Elevator I.D. #2
I assume that you planned to attach some photos to that post??
/ Hay Elevator I.D. #3
Was it silver? Long and narrow? I think it was made in the 20th century, likely the last half...
Carnac the Magnificent
/ Hay Elevator I.D.
I will take a pic tomorrow that is smaller so that it can load
/ Hay Elevator I.D. #6
You can open photos in Microsoft Paint and resize them using the resize command and try 25% or less to reduce the file size.
/ Hay Elevator I.D. #11
I have seen one of those before, but I do not recall the make. It was probably made in the 1950's.
/ Hay Elevator I.D. #12
There not really much to them, most of the part can be found at a Tractor Supply or a similar store. You can also get a lot of bearings and power transmission component at Surplus Center online. What specifically is wrong with it?
2011 John Deere 7330 (A64911)
2011 John Deere...
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
25210SFL (A64557)
25210SFL (A64557)
27001CFL (A66736)
27001CFL (A66736)
2022 John Deere 6175M (A64911)
2022 John Deere...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
