Hay Baler fan
/ Hay Baler fan #1
Lone Wolf
Florida
Kobota
Anybody use a small fan on their baler to keep the hay/dust of the knife/cutting area? I thought about getting a fan from Wally world and connect to a battery which would be located in one of the storage binds on the side. Thanks
/ Hay Baler fan #2
I would be worried about the fan motor filling with that fine dust and starting a fire. If you can get a fan with a sealed motor then maybe but I think if you just clean it off at the end of the day you will be fine.
/ Hay Baler fan #3
G'day common enough to se them fitted to the big square balers so much so that some even come with them from factory now, have never seen one fitted to a small one though.
Jon
/ Hay Baler fan #4
Most just carry a leaf blower with them and clean 2 or 3 times a day !
/ Hay Baler fan #5
Do a google search for HECO baler knotter fans
/ Hay Baler fan #6
Dang! That's somethin'... Are you talkin' about those 3x3 square balers? I'd feel kinda silly doin' that on my little square baler!
I just puff out my cheeks a few times every day. :rolleyes:
AKfish
/ Hay Baler fan #7
Leaf blowers work well for in the field for removing the chaff!
Do have googles handy!!!!
/ Hay Baler fan
How were you able to use the blower in the field as far as hook up, Thanks
/ Hay Baler fan #9
/ Hay Baler fan #10
I thought big square balers used pressured air (with a compressor) to really blow the hay/straw particles away. I have been thinking of something like that for my small square baler. You could place the outlets exactly where you want them. Gotta check out HECO website now.
/ Hay Baler fan #11
Why? I've never had trouble with chaff and properly tuned knotters. They push it out of the way on their own.
/ Hay Baler fan #12
The fines build up on the knotters but not enough to interfere with the operation. I just brush it off when I fill the twine box.
/ Hay Baler fan #13
I've never had a problem just blowing it out at the end of the day or as mentioned just a quick brush when putting in new twine.
/ Hay Baler fan #14
Heco knotter fans are stupid expensive. Why not get a couple pusher 12 volt fans from Flea Bay for 10 bucks each, mount them, run a 12 volt lead back to the tractor with a switch and be done with it, cheaper than a gas powered leaf blower.
The Heco fans are a stupid 220 bucks each. Thats insane.
/ Hay Baler fan #15
As others have said If it ain't broke why fix it? I have used a baler for a week and not blown it off.
MF GC2300 fel replaced
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
2020 ASV RT65 (A60462)
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
