Hay Baler fan
/ Hay Baler fan #1
Lone Wolf
Member
Florida
Kobota
Anybody use a small fan on their baler to keep the hay/dust of the knife/cutting area? I thought about getting a fan from Wally world and connect to a battery which would be located in one of the storage binds on the side. Thanks
/ Hay Baler fan #2
I would be worried about the fan motor filling with that fine dust and starting a fire. If you can get a fan with a sealed motor then maybe but I think if you just clean it off at the end of the day you will be fine.
/ Hay Baler fan #3
G'day common enough to se them fitted to the big square balers so much so that some even come with them from factory now, have never seen one fitted to a small one though.
Jon
/ Hay Baler fan #4
Most just carry a leaf blower with them and clean 2 or 3 times a day !
/ Hay Baler fan #5
Do a google search for HECO baler knotter fans
/ Hay Baler fan #6
Dang! That's somethin'... Are you talkin' about those 3x3 square balers? I'd feel kinda silly doin' that on my little square baler!
I just puff out my cheeks a few times every day. :rolleyes:
AKfish
/ Hay Baler fan #7
Leaf blowers work well for in the field for removing the chaff!
Do have googles handy!!!!
/ Hay Baler fan
How were you able to use the blower in the field as far as hook up, Thanks
/ Hay Baler fan #9
/ Hay Baler fan #10
I thought big square balers used pressured air (with a compressor) to really blow the hay/straw particles away. I have been thinking of something like that for my small square baler. You could place the outlets exactly where you want them. Gotta check out HECO website now.
/ Hay Baler fan #11
Why? I've never had trouble with chaff and properly tuned knotters. They push it out of the way on their own.
/ Hay Baler fan #12
The fines build up on the knotters but not enough to interfere with the operation. I just brush it off when I fill the twine box.
/ Hay Baler fan #13
I've never had a problem just blowing it out at the end of the day or as mentioned just a quick brush when putting in new twine.
/ Hay Baler fan #14
Heco knotter fans are stupid expensive. Why not get a couple pusher 12 volt fans from Flea Bay for 10 bucks each, mount them, run a 12 volt lead back to the tractor with a switch and be done with it, cheaper than a gas powered leaf blower.
The Heco fans are a stupid 220 bucks each. Thats insane.
/ Hay Baler fan #15
As others have said If it ain't broke why fix it? I have used a baler for a week and not blown it off.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A60352)
2006 Ford F-750...
2017 Ford Escape (A61569)
2017 Ford Escape...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
