Have given up on my Land Plane
   / Have given up on my Land Plane #21
I have used my ROBB to "fix" the woopite-doos. However - to get the "fix" to last longer - you should scarify the low areas first. This will allow the imported material to incorporate into the low area. Otherwise - the imported material just sits there - on top - and will be kicked out with each passing vehicle.
Actually - I find it's a whole lot easier to just leave the woops alone. It's only a 150 foot section on my mile long driveway. I could spend a whole lot of time making it smooth AND level. Next spring - here comes the water off the neighbors big field and I, once again, have JELLO.
   / Have given up on my Land Plane #22
I bought a unit last year to try to level my driveway. I have gentle rolling humps I call "whoopity-dos". It feels like riding a little roller coaster. I created most of the problem trying to initially use a back blade. Once a hump is introduced, it just makes the problem worse with each pass.
Over the last year, I have spent about 12 hours going up and down the drive (300 yards) and the land plane has helped a bit but not enough. Disconnected the hydraulic top link and used a chain hoping it would help but that did not work that well either.
The land place works well on the rest of the drive that is flat but not where I have the undulations.
Thought about adding 10 ft runners to the land plane to help. Two PT 2x8's will cost $35 but mounting them will not be easy. My neighbor has a box blade but his driveway is not much better, so not sure how well it will work, plus I hate borrowing stuff.
I have a contractor coming in to look at getting the job done next month.
Any advice?
Put some gauge wheels on your back blade, rip up the surface and then work a windrow back and forth across the road.
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2020 Deere 50G (A53317)
2020 Deere 50G...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
