Have a weird Septic issue
/ Have a weird Septic issue #41
They can't snake...does that mean they will let you snake back from the manhole?
/ Have a weird Septic issue #42
Can you LOOK in the manhole, turn on the pump, and see if anything comes out,, ?? :confused2:
No snake needed to take a peek,,, :thumbsup:
I do see water, but it doesn't flow very fast. I think I found the issue though. I dug around where the 1 1/2" discharge line is and it comes out 1 1/2" PVC but there is a reducer that goes to 1" then to black poly pipe. So if my pump can pass 3/4" solids and it goes into a 1" pipe, it's definitely going to clog up.
They will, but I don't have a long enough snake. I did do an actual measure and the discharge line is about 225' and the rise is about 24', so that was a pretty close guess. I was about to measure the elevation difference with a rotary laser level.
/ Have a weird Septic issue #46
I haven’t seen raw affluent pumped in anything smaller than 1 1/2”. Looks like the previous install was a real sh...t show! In more ways than one. Glad you found the issue.
/ Have a weird Septic issue #47
Yep, that would be the restriction.
Those pumps are designed for 1.5 to 2 inch pipe.
For a 225 foot run, I would think 2 inch would be recommended.
You will need to run new pipe and make sure you install a check valve close to the pump and a gate valve after the check valve.
The gate valve is so you can service the check valve and the pump in the future.
Here is a diagram and a link in case the diagram does not display properly from my phone.
Google Image Result for https://www.plumbingsupply.com/images/sewage-ejection-package-typical-installation.png
I called the sewer authority. I am permitted to run a new line and attach it to the sewer main, they will need to inspect prior to me burying the pipe. They are sending a crew out to see how the current pipe is attached. They have been so helpful during this whole process.
/ Have a weird Septic issue #49
Really great that you have discovered the problem and that your local sewer authority is being so helpful. Some municipalities aren't so co-operative and demand permit after permit and of course fees to pay for each permit and inspection process. Sounds like your will be all set to go in short order.
/ Have a weird Septic issue #50
Good drawing. But for scale the pit in the photo is only about 18” deep. This puts the check valve within about 2 vertical feet of the pump. In the OP’s case the check valve etc will need to be in the pit next to the pump......I thank that’s what he’s describing anyway ;^)
What I am going to purchase is an EOne system. The township recommends that brand and I put one in at my other house that I lived in. They are a little more pricey, but they are good pumps of what I have experienced. It comes already assembled, no floats, it's all electronic switches which I prefer. 2 year warranty. The other thing I like is once I install it, the coming that is selling it to me will come onsite, verify it is installed to specs and test it at no charge.
This is the one here: Grinder Pumps :: Grinder Pump Systems - Environment One
The first picture is the manhole. You can see the 6" pipe stub out. I dug about 10' back from the manhole a found where the 6" goes to 4", then down to the 1" black poly. I still cannot believe they ran that. I got the trench dug and got the 1 1/2" line ran. Now I have to call to get it inspected. Next weekend I'll install the grinder.
/ Have a weird Septic issue #53
:shocked: who ever though that would be ok?? At least they could have upsized the black poly. :duh: good job figuring out your dilemma.
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
New/Unused Deluxe Massage Chair (A65583)
New/Unused Deluxe...
1/4" Quick Attach Blank Plate (A66408)
1/4" Quick Attach...
REEL RAIN HARD HOSE TRAVELER (A64278)
REEL RAIN HARD...
UNVERFERTH 2755 SEED RUNNER (A64278)
UNVERFERTH 2755...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
