Have a weird Septic issue
   / Have a weird Septic issue #41
They can't snake...does that mean they will let you snake back from the manhole?
   / Have a weird Septic issue #42
Can you LOOK in the manhole, turn on the pump, and see if anything comes out,, ?? :confused2:
No snake needed to take a peek,,, :thumbsup:
I do see water, but it doesn't flow very fast. I think I found the issue though. I dug around where the 1 1/2" discharge line is and it comes out 1 1/2" PVC but there is a reducer that goes to 1" then to black poly pipe. So if my pump can pass 3/4" solids and it goes into a 1" pipe, it's definitely going to clog up.
They will, but I don't have a long enough snake. I did do an actual measure and the discharge line is about 225' and the rise is about 24', so that was a pretty close guess. I was about to measure the elevation difference with a rotary laser level.
   / Have a weird Septic issue #46
I haven’t seen raw affluent pumped in anything smaller than 1 1/2”. Looks like the previous install was a real sh...t show! In more ways than one. Glad you found the issue.
   / Have a weird Septic issue #47
Yep, that would be the restriction.
Those pumps are designed for 1.5 to 2 inch pipe.
For a 225 foot run, I would think 2 inch would be recommended.
You will need to run new pipe and make sure you install a check valve close to the pump and a gate valve after the check valve.
The gate valve is so you can service the check valve and the pump in the future.
Here is a diagram and a link in case the diagram does not display properly from my phone.
Google Image Result for https://www.plumbingsupply.com/images/sewage-ejection-package-typical-installation.png
I called the sewer authority. I am permitted to run a new line and attach it to the sewer main, they will need to inspect prior to me burying the pipe. They are sending a crew out to see how the current pipe is attached. They have been so helpful during this whole process.
   / Have a weird Septic issue #49
Really great that you have discovered the problem and that your local sewer authority is being so helpful. Some municipalities aren't so co-operative and demand permit after permit and of course fees to pay for each permit and inspection process. Sounds like your will be all set to go in short order.
   / Have a weird Septic issue #50
Good drawing. But for scale the pit in the photo is only about 18” deep. This puts the check valve within about 2 vertical feet of the pump. In the OP’s case the check valve etc will need to be in the pit next to the pump......I thank that’s what he’s describing anyway ;^)
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2025 Swict 72in Bucket Skid Steer Attachment (A55787)
2025 Swict 72in...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A55787)
2025 MS380R Mini...
